Question about Canon i850 InkJet Photo Printer
Repeating smudge along the left side of the paper
There is a repeating pattern in the margin of the paper along the left side. Sometimes it is 4 cm apart, sometimes it is 4 mm apart. Either way, it looks like I took a potato and carved it into a Christmas tree stamp and decorated the edge of my tax returns. Help! I need to be able to print clean printouts by April 15th.
  • 1,602 Answers
MACHINE NEEDS A MAINTANCE CLEAING AND THE OVERFLOW TANK NEEDS TO BE EMPTIED
GO ON LINE AND TYPE
CANON 850i NEEDS SERVICE AND INSTRUCTIONS ON HOW TO
ROD
Posted on Feb 04, 2009
Edges of prints are black smudged
MAY BE DRUM UNIT IS END OR LASER UNIT
JUST SEND A COPY VIE MY MAIL SHAMMINOLTA@GMAIL.COM
Dec 14, 2013 | Brother MFC-8460N All-In-One Printer
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
HP Laserjet 1012 - Little smudges on page.
You probably have an excesive amount of toner building up on your rollers or fuser. A cleaning done by a certified technician should take care of this problem for you.
May 28, 2010 | HP LaserJet 1012 Printer
3 dots along the left margin of paper, after replacing the drum
Open the MP tray and place a new sheet of A4 paper on it.
Press and Hold the Clear/Back button and also press and hold the Left Arrow. The display should change to 'Drum Cleaning'
Press the OK button and it should clean the drum and print a sheet with smudges where your dots used to be.
You may need to repeat the procedure a few times.
Apr 24, 2010 | Brother MFC-9440CN Laser Printer
Pale smudges regularly spaced down left margin, 1.5 inches apart
Hi:
Since you have already replace the toner cartridge then the most likely culprit is the fuser assy. You can test this by trying to print something and stop it by opening the cover just as the paper is trying to pass under the toner cart. Remove the toner cart carefully and look at the unfused print on the paper. Do you see the faint smudges? If not, then the problem lies with the fuser assy. This is the unit that gets hot and fuses the toner to the paper. If this is the case you will need to have a tech replace it for you.
Good Luck
Andrew
Jun 27, 2009 | Brother HL 5250DN Laser Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Toner smudges along the extreme right side of the paper
If the smudges are gradually fading then it's likely just excess toner hitting the fuse drum. Try a few cleaning cycles/test prints and see if that makes it go away. If not, see if you can get a replacement toner.
Jan 05, 2009 | Brother HL 5250DN Laser Printer
Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Nov 07, 2008 | HP LaserJet 4 plus Printer
Canon i850 InkJet Photo Printer Logo
121 people viewed this question
old marine
old marine
