We have an Acer 3650 laptop loaded with Vista. The wireless connection has dropped off and we don't know how to get it back - can you give me an easy to follow instruction on how how to do this? Thanks.
    Sergeant:
  • 313 Answers
First make sure the Wi-Fi connector didn't get accidently turned off.
On the front of the computer, (right in the midde) is the wireless button, Press to enable/disable it. Try that first.
PS - you can download the manual here: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=caf09f1c3e92ebda8a9d9dcd8625b7f0&q=Acer+Aspire+3650
Posted on Apr 06, 2008
Acer aspire 4250 wireles problem (may due to adapter setting.
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Windows 7 Acer AspireLaptop wireless
Wireless Internet is a convenient way to hook up multiple computers to one router without the mess of cords.
The router or 2-in-one (router/modem combo), must be set up through your Internet Service Provider and connected with either a DSL line or Cable.
Since most Acer laptops have built-in wireless, no additional hardware is required.
Turn on the laptop.
Move the switch located on the front of the laptop to the right, then let go.
The switch will go back to its original position.
Confirm that the wireless networking icon has appeared on the screen.
Right-click the wireless icon in the bottom right corner.
In Windows 7 this will resemble a small stair-step triangle; In Vista it looks like a tiny monitor.
Click "View available wireless networks."
It might also say "Open network and sharing center."
Wait while the adapter finds your wireless network.
Click to highlight the network and click the "Connect" button.
Enter the security password that you created when setting up the router (if applicable).
If you don't know or can't remember, log in to the gateway page specified in the user's guide.
Locate the "Wireless security" settings page to see if security is enabled.
If it is, type in a new key and enter the same number for the wireless network.
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire1300/Aspire1300faq27.shtml
Feb 19, 2014 | Acer Aspire 4520-5582 Notebook
Wireless connectivity is very poor to my acer aspire 5920
I don't know the make of the wireless access point that you are using. First I would unplug the wireless access point, unplug the computer, remove battery, plug in the wireless access point, it will do a self test, when it completes plug in the laptop. You may have interference in your area? Is your wireless access point secured with a passcode? You can also change channels from defaults. I am not sure why you would reformat a machine due to wireless connectivity? You could re-set the wireless access point to defaults by pressing and holding for 30 seconds the reset will return the device to defaults, of course you would have to reconfigure the SSID and security code.
Nov 16, 2012 | Acer Aspire 5920-6335 Laptop
My netbook won't let me connect to a wireless network, it tells me to reset my wireless adapters. I don't know how
To reset the wireless adapter, click "Start", click "Control Panel", and go to "Network Connections" (XP) or "Network and Sharing Center" (Vista or 7), Vista and 7 will have to click "Network Adapters" from there. This should bring up a screen with all available network adapters. Right click the one that likely has the word "wireless" or a "g" "b" or "n" in the name, and click Repair or Reset.
Aug 24, 2011 | Acer Aspire One D255-1625
How do I turn the wireless connection back on
either with the switch on pc or in control panel. wifi wizard should be used if possibe thre make new connection
Oct 06, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire Computer
Hi there.
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Jun 30, 2009 | Acer TravelMate 661LCi Notebook
Can't connect to netgear wnr 2000
conect to netgear then shut down and turn it back on.
May 27, 2009 | Acer TravelMate 5520 Notebook
I am trying to connect to new acer laptop to my wireless network, but my acer empowering technology toolbar, located above my keyboard, does not seem to be working to allow me to connect to my wireless...
Hey
for this you gotta now the following:
1. ssid : this is the name of your access point (router)
2. key/passphrase: this is the network security key you configure your router with (if your router has a default configuration (the one that came with the device right out of the box which is not recommended) your key may be a blank key ... you simply don't have one set up.
3. the encryptation method: wep, wpa, wpa2. this goes again to how you have your router configured and if your don't have anything configured with your router in regards to encriptions (not recommeded) you may simply not have any encryptation that you need to select here.
important:
make sure your wireless adapter is working and is on:
your laptop may have a switch on the front to turn your wireless adapter on (i don't know what model of laptop you have so you may want to check the user manual that came with laptop to find the switch) or you may have to turn it within windows. (also check the user manual of your laptop)
now that you have the info needed and your adapter is on there are 2 ways to do this:
1. using your beloved acer empowering technology:
I found this that may guide you through the process of setting up your wireless connection
ftp://ftp.support.acer-euro.com/notebook/empowering_technology/acer_enet_management.pdf
look under the title: SETUP A NEW PROFILE and follow the instructions..
now if acer empowering does not work... you can try to setup your wireless connection with windows,
2. Using windows vista to setup your wireless connections:
I'm assuming you're using vista so here's a set of instructions with pictures you may want to take a loot at and follow
http://www.home-network-help.com/vista-to-connect-wireless-network.html
let me know how it went!
if problems.. post what you see and we'll try to give you hand. (please give as many details as possible)
Oct 03, 2008 | Computers & Internet
Wireless connection lost
948c84d.gif Make sure #4 is switched to the ON position.
Then, double click on the wireless indicator located on your taskbar, near the clock in the lower right hand corner of your screen. That will tell you if it "sees" any wireless connections available to it.
You can download the manual for this laptop here: http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/a9b67d2003ba6822482571f8000f317e/$FILE/AS5680_5630_3690-ENG-OLM_0727.pdf
Let me know if this helps.
Apr 06, 2008 | Computers & Internet
Wireless Adapter
Are you sure that you installed the windows xp drivers and not the vista drivers? There may be no xp drivers for your laptop, and if thats the case, you'll have to switch back to vista. Make sure you know 100% that its the xp drivers.
Sep 18, 2007 | Acer (D10709-002) (D10709002) 802.11g/b...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
