RCA MODEL F36676ET PICTURE CUTS THEN WE GET STATIC BUT WE WE BANK WITH OUR HAND IT COMES BACK IN. WHAT COULD BE WRONG? A FLYBACK?
How to unlock my memory card password
Posted on Apr 06, 2008
Picture tube will not come on.... rca mod f35731 mb chassis ctc169j56 ser 707261399h green light comes on but no picture.... help fuse?> bad picture tube...?
Bad grounds on the power supply are common on these TVs. The power supply will have the flyback transformer. Resolder the flyback, horizontal driver transformer, power resistors etc. Check and study the vertical IC and see if the pins will need resoldering as well. Inspect the small board that is connected to the CRT, and solder this, as necessary. This is a good start for repair, thanks for asking and show all hands of support!
Jul 28, 2011 | RCA Televison & Video
When i turn the tv on i hear a static sound and then the tv shuts off automaticlly each time
The flyback needing replacement is the most likely cause. You can get replacement flybacks for your model at www.tvrepairworld.com the flybacks come with installation instructions on CD.
Aug 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on RCA45 inch tv model D52W20B
The flyback is going out and the CP150 capacitor is almost certainly failing as well. You can get the replacement Flyback number 259296 and the CP150 Capacitor at the following link and they provide step by step instructions with pictures so you can easially do the repair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Does not work
sounds like the flyback is out. Thats a common issue with that Model. You can get a replacement flyback at the following link.
Jun 06, 2008 | RCA HD52W56 52" Rear Projection HDTV
Part #H Q401 1511936A
A common cause is a failure in the horizontal output stage. I have had a defective flyback transformer cause this.
Also, when the flyback fails it sometimes takes out the horizontal output transistor and some other parts with it. It is possible that the power supply has some damage from the failure.
Jerry G.
Apr 19, 2008 | RCA F36676ET 36" TV
RCA F36685 wont power on
Probable bad flyback transformer....verify service number
last three digits YX2....Part # is 244247.............................T.
Nov 28, 2007 | RCA F36685 36" TV
Rca d52w19 power but no picture...
Solder around flyback pinns this should fix it.
Oct 09, 2007 | RCA D52W19 52" Rear Projection Television
RCA F36676ET TV problem
its ur horiz. output transistor i just fix mines
Sep 05, 2007 | RCA F36676ET 36" TV
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
I have sound but no opicture
When you replaced the flyback the new flyback is shipped with the screen and focus controls set at minimum. These are the 2 controls on the flyback itself. Turn the set on and let it warm up a minute, then slowly turn up the screen (bottom) control with a small flat-head screwdriver. When the picture is around normal brightness, adjust the focus (top) control until the picture is nice and sharp. Then, turn the brightness and contrast all the way down and set the screen control until you can just see the picture, just above the point where the picture vanishes. Reset the brightness and contrast settings and your picture will be back to perfect.
Jul 02, 2007 | RCA F36650 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
