Question about Nokia 6600
Notworking of the keys 3-6-9-#
All these keys mentioned above are not working since last 1 hour pls help?
Posted on Apr 10, 2008
98 isuzu amigo 2.2L 5sp 2wd new NGK plugs & wires, fuel assembly, rail test, code -cam pos sensor?? still bucks, lurches, can't get 2 4,000 rpm 2 reset pcm, WTF?? 120,000 odo. Help us pls sir.
2.2L gas 2.2-liter petrol (X22SE)
or 2.2L
2.2L (X22se/D) Engine???
there are 3 engines
i cant guess engines yet, "Carnac the mag." is off line.
all i can tell from above is engine misfires.
when did it last run ok,, last week , last year, or found car in a barn.
history matters.
why not connect any $10 to $100 scan tool and scan it
running,,, it will infact ,tell you things, errors,called, DTC errors.
and is key to any diagnose of any modern engine in USA>.
even in canada the tool works starting in 1998.
is cam belt fresh? and timed correctly?
AMIGO, 2.2L (1 of 3)
first learn what under the hood.
please post what 2.2L is there. and fuel type.
gas, diesel ,petrol, ect
Mar 15, 2016 | 1998 Isuzu Amigo
My touchpad is not working but when I connect an external mouse t the USB, it works properly. Pls help.
1. check is there any botton just above the touchpad.
2. if there is a key then press once & it will start working
3. else update the drive of the touch pad.
4. if not working the take it to a service centre for replacement.
Aug 13, 2010 | HP Compaq nx7010 Notebook
Blue screen error
if your geting blue screen when your starting up your PC
it mena there is a 2 problems
1 is your RAM is not working properly or RAM is gone i mean notworking
2 is if your RAM is working then you have problem with you HDD this two thing are not working propely then only your getting above screen
Apr 27, 2010 | Dell Inspiron 1525 Notebook
How to reset security code for nokia 3120 classic, i cant use my phone...
I put a security code to my Nokia 3120 classic mobile. But suddenly it asking me the security code n when i provide the correct one it says code error. www.UnlockMe.co.uk doesn't work. They mentioned there that 3120 classic phone is incompatible for this master code method. pls give me a solution......
Jun 07, 2009 | Nokia N72 Cellular Phone
My nokia 6670 wont start..pls i need help
Remove your battery.Wait about 30 seconds.
Then follow these steps
1.Insert The battery
2.Press and hold the key combination given below
      "Green Key" + " * key" + " 3 key"
3.while holding down those keys press and hold " Power key" until you see regional settings menu appears.
notes
1.Though this is a standard method,I'am not responsible for Any loss of data or any damage caused by doing whatever I mentioned.Do with your own risk.
2.All the keys mentioned above must be press and hold without releasing.
Jun 02, 2009 | Nokia 6670 Handheld
I cant find cd key of Norton Antivirus 2009
Looks like this is not legal copy of Norton Antivirus
Mar 31, 2009 | Computers & Internet
Pushed cook button with nothing in oven now it doesn't work at al
Try to unplug your microwave then leave it for 1 hour the purpose is to reset and drain stored current after 1 hour plug it again ,if still notworking there something wrong inside. Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows,you need to replaced it or you need to have a qualified appliance repair technician replace it.
Hope it may help you;
Regards
VOTIT
Jan 28, 2009 | GE JVM1860 Microwave Oven
IRQL_NOT_LESS_OR_EQUAL
1. purchase a 2.5" usb enclosure.
2. remove your hard drive and install in the enclosure.
3. plug the enclosure into a working computer and copy or move your important files onto working computer.
4a. reinstall the laptop hard drive and try a repair installation by booting from the XP cd. (if you are running xp)
4b. reinstall the laptop hard drive and try booting to Last Known Good Configuration. Press either the F5 or F8 key while rebooting to get to the menu.
4c. purchase a new hard drive and reinstall the OS using the reinstallation cd's
Dec 09, 2008 | Dell Inspiron 1501 Notebook
97 nissan pickup
bought a 96 nissan last year (2008) and had the same problem for a while. It seemed that it only happened with 1 of the 3 keys i had. my girlfriend sat in a parkinglot for almost 4 hours before someone helped her out although no discovery of what the problem was.
at times the problem was because the wheel was locked and turned too far over. with key in ignition and "turning" it as if your starting the car, give it a nice **** in the opposite direction. this sometimes fixed the problem but was not a solution.
then a friend mentioned that you have to insert the key into the ignition and then you pull it back out JUST A LITTLE BIT, i repeat, A LITTLE BIT. if you do this slowly you should feel it "unlock".
(i dont recall if he mentioned that this was on all cars up to a certain year or just on Nissan's.)
that worked. NOW, WE JUST DONT LOCK THE WHEEL...EVER!!
hope this helps!!
Oct 07, 2008 | 1997 Nissan Pickup
Hi Sonubaath
press *# 7370 # your phone will format.....
Jul 30, 2008 | Nokia 3230 Cellular Phone
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
