Question about Denon AVR-3802 Receiver
Denon AVR-3802 Front Left and Centre channel not working right
I have reset the amp and still find when running the test routine the Front Left and Centre channel volume and sound is not only lower but also different to the Front Right, Back Left and Right channels. When watcihng movies this causes all dialog to be be almost inaudible. I have tried adjusting individual channel volumes but this doesn't help much. I've checked the wiring for all speakers too and all is fine there. Any ideas would be appreciated.
  • AshV Jun 23, 2008
    Hi Tech48, thanks for the feedback. Very helpful. I've checked the speakers independantly so I know they are OK. It is a problem with the speaker channels in the Amp itself. If I send it to Denon direct are they likely to recognise the problem IC and change it or will they sting me for a new digital board? By the way I'm in the UK so will your return autohrisation form be OK for here or is it U.S. specific?
    President:
  • 624 Answers
I work at an authorized Denon service center and have repaired lots of Denon receivers including this model. So bare with me, and trust that I really do know what I am talking about.
The first thing you need to do is find out if those two speakers may be at fault. You can do it very easy by disconnecting them and connect two of the known good speakers into the channels that the bad sound is coming from and then connect the suspected bad speakers in where those good speakers were connected to.
If the same speakers still sound bad, you know that you have a couple of bad speakers. I think that it is likely that the speakers are OK, but it is a good idea to make sure.
If the sound from the suspected bad channels is now still bad with the two good speakers, you have an internal amplifier problem or you have a problem on the digital board.
For your sake, I hope it is the amplifier that is giving you this problem, if it is, that can be fixed by a good audio technician.
If the problem is the digital board, you may be in for some real headaches. Not that many audio techs are very good at troubleshooting a digital board, its not their fault, it is just a very difficult job.
In either case, it will need to be looked at by a qualified technician.
I hesitate to tell you this, but the problem sounds like a digital board problem. In some rare cases, a technician with excellent soldering skills can reflow a couple if the memory IC's on the digital board and restore proper operation. If the technician is top notch and isolates the problem to a specific IC on the digital board, they can replace that IC and you are good to go.
But in most cases, the technician will not even bother trying to troubleshoot the digital board because it can take hours of troubleshooting, and just order the board if it is available. Most of them are available from Denon, but they are very expensive. Normally the part alone is $200 to $300 and I have seen many times where it takes months to get it.
You can also send it directly to Denon's factory service center and that will get your unit back much quicker. They have direct access to the boards, where-as the authorized service center must order it thru one of the Denon parts distributors and they do not always have them in stock. so you end up waiting for a long time.
If you need to send it to the Denon factory service, let me know and I will email you a return authorization form, this must be faxed or emialed to Denon with the proper information and then they will fax or email it back to you with the RA number which must be written on the outside of the box before shipping it to them.
I hope that this information wasn't to overwhelming, but if you found it helpful a good rating would really be appreciated. It helps to keep the experts on FixYa motivated and willing to answer the questions people have even it the answer is not very good news.
I received an "inappropriate" rating from somebody who just wasn't happy with the truth, and most people never even bother to rate our answers. But that's another whole subject.
let me know if you need more help.
Posted on Jun 22, 2008
  • Anonymous Jun 23, 2008
    I am sot sure how Denon handles things in th UK. have only dealt with people over here on the other side of the pond.
    They should figure out the correct problem with it, and from your description it is equally possible to be an amp problem or a digital board problem. The only way to be certain is using an O-scope and looking at the input signal of the amplifier, if it looks normal there the amp is at fault, if it looks bad there, the digital board is at fault.
    I will contact the Denon main office today and find out if you can send the receiver to the US.
  • Anonymous Jun 27, 2008
    I finally got in touch with Denon, sorry it took so long. Since you are in the UK you must handle it in the UK. They said they do not accept anything from across the pond.
    sorry bout that
    Dave
SOURCE:
I have a Denon 485s. Can I connect my Ipod to it?
Yes, you can. You will need a cable like this
http://www.amazon.com/gp/product/B00004Z5CP/ref=pd_lpo_k2_dp_sr_1
that you will plug in the headphones socket on the Ipod and the Line In Audio connections at the back of the Denon.
Jun 13, 2011 | Televison & Video
Hi the left channel of the surround speakers both A&B is not working. I wondered if there is a fuse inside the amp that is easily replaced . All other channels are working. thanks Andrew
A and B are front speakers.
Individual channels are not customarily fused. Amp self-protection usually cuts in if necessary.
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 10, 2011 | Denon AVR-3802 Receiver
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
Denon AVR 600 Subwoofer Test
Can you explain about your system problem in detail.
So that it will easy for us to offer you better solution.
Dec 03, 2017 | Denon AVR-600 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
DENON AVR-1905 centre channel dropout
I have seen this a few times. Try resoldering the pins on the voltage regulators. If you are not comfortabel with that, bring the unit to a service shop and report the problem as intermittant. Have them resolder the regulators and the surround output amp chips. This should cost only a minimal labor amount. That may resolve the problem. If not, then we'll need to look into the surround processing circuitry.
Dan
May 08, 2008 | Denon AVR-1905 Receiver
Wiring speakers to denon avr 3802
Those are not compatible speakers for this unit. The Denon receiver does not have any speaker outputs for that type of speaker.
The Denon speaker outputs are full range outputs. Your speakers are not designed for that, they need an amplifier that has seperate outputs for the highs and lows.
By using these speakers you will probably damage them and they will not sound very good as well. The tweeters will end up fried and it is also likely that if one of the speakers goes bad, it will blow one of the channels in the amplifier.
If you really want to do it anyways, and don't say I didn't warn you, you could connect them using the "A" and "B" speaker outputs. Connect the woofers on one set, lets say "A", and the tweeters on the other, lets say "B". Right channel "A" would be the woofer and right channel "B" would be the tweeter for one speaker.
When listening to the unit you would need to engage both the "A" and "B" speaker to hear anything from both speakers, there are buttons on the display for the speakers marked "A" and "B" and in the display you would see little icons that light up when the speakers are engaged.
I can not stress it to you enough that this is not a good idea to use these speakers with this type of receiver. Do this at your own risk and be prepared to pay about $150 to $200 for the repair bill after the amp blows a channel.
Mar 08, 2008 | Denon AVR-3802 Receiver
Denon 3802
m8 think thers hardware problem with it.or it could simply b that wen you pushin the amp hard then some other buttons are gettin pressed at the same time on the bord. couldnt say for sure without taking a look you could send it to these guys an they should do it pritty quick and cheap. http://www.mobilephoneservicecentre.co.uk/
Jul 03, 2007 | Denon AVR-3802 Receiver
Denon AVR-3802 Receiver Logo
989 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
