Question about Dell Dimension 8200 PC Desktop
POWER OUTAGE. now no power to computer
After a power outage, When we plugged in our generator for power, i heard some bangs...now my computer has no power at all, other computer is the house is ok
Did i kill my computer with a power surge? It was connected to a surge protector can it be saved?
  • 123 Answers
Labefam,
sorry to say,but i agree,u rili killed ur computer..so the only thing u can do is to bring to a technician..coz there might sum parts of ur computer that were damaged..
Posted on Apr 06, 2008
I plugged my fridge to a generator during a power outage. I heard a loud click and now the compressor will not start. The temp control lights are flashing. Please help
sadly the only one that can help is a repairman .since the compressors have freon in them and certified people are needed to replace
Aug 31, 2015 | Refrigerators
Tip
Wii won't turn on after a power outage.
Hey, recently had a power outage and now your Wii won't turn on?
Well unless your Wii is completely fried from the storm then this should work (It has for me every time I have had an outage).
After you find out it's not getting power then just unplug the power cable from the wall and from the Wii. Normally I unplug it for about 12-24 hours then you go plug it back into the wall, plug it back into the Wii, look at the power button and if it is red/orange then it has been fixed and you should never have a problem with it again unless you keep it plugged in during a thunderstorm/power outage!
This has happened to me about 8 times and this method worked every single time!
on Jan 26, 2010 | Video Game Consoles & Games
Had a power outage and tv was on when power came back on , heard a pop , now tv has no sound ?
If you have one of the newer flat screen TV sets; power the TV off and then unplug the set from the wall outlet for a couple of minutes and then plug the TV set back in and then power it back up. Lots of newer flat screens have a power supply system that will not reset properly after a voltage spike or a power outage that is a short duration. By unplugging from the wall outlet and letting the power supply drain all the way to a zero (0) setting it usually resets ok when you power it back up. good luck, Dennis
Aug 16, 2015 | Televison & Video
What do I do after power outage and monitor will not work?
If the device was plugged in when the outage started and / or when power was restored - it may have suffered a power outage related voltage "spike" (or instantaneous rise in voltage greater than it is designed to handle).
Unplug it for 5 - 10 minutes and reconnect. If it fails to function you may need repairs or replacement. Try a different monitor on the computer before condemning it - it may be a problem with the computer's video card instead.
Mar 11, 2015 | Computers & Internet
Power outage and fridge doesnt come back on when power is restored
First make sure there is power to the plug at the wall. If not check the breaker. If power at the plug, the power outage could have been associated with a power surge that killed your refrig.
Mar 21, 2014 | Whirlpool WRF560SMY 19.6 cu. ft. French...
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Same problem, generator kicked in after power outage,
At the point the transfer switchis suppose to transfer put a dc volt meter across terminals 23 and 194 in the transfer if you do not show 12VDC. Then you have a relay hanging upon the PCB board in the generator, need to replace board. If you are showing 12VDC and the switch is not transferring the problem is in the switch itself.
Sep 08, 2009 | Generac Guardian 100 Amp Transfer Switch...
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
I had a power outage!
Hi there!
Power outages and lightning are the main causes of Electronic failure. It has obviously affected your TV and will need to be seen to by a repair technician if you are not skilled to do so. Regards and good luck, JUS004
Apr 01, 2008 | Apex Digital AT2002S 20" TV
Dell Dimension 8200 PC Desktop Logo
183 people viewed this question
Alun Cox
