Question about Kodak EasyShare Z760 Digital Camera
Kodak easyshare Z760 battery and card holder fail
When inserting both battery and mem card into camera it fails to "click" into place and hold it. Any suggestions?
  • 44 Answers
Mine does same thing, although when I close the little door, it still works fine.
Posted on Mar 15, 2010
WHAT IS THE BEST MEMORY CARD FOR THE z760 CAMERA
The Z760 works with MMC and SD cards. MMC cards are all but extinct, and samples will likely cost more. MMC and SD cards max out at 2GB, so make sure you get one no larger than 2GB. SDHC cards start at 2GB but won't work in the Z760.
You can use any speed and brand of SD card, but personally I'd go with one of the major brands.
Dec 07, 2012 | Kodak EasyShare Z760 Digital Camera
8GB sd mem card will not format. what is the max size of SD card that can be used in a Kodax Easyshare Z760?
The Z760 uses SD cards, which max out at 2GB. Larger cards are actually SDHC cards (the HC stands for High Capacity). While SDHC cards will fit into SD slots, they will not work.
Aug 04, 2010 | Kodak Cameras
Memory card will not format in Kodak Z760
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 22, 2010 | Kodak EasyShare Z760 Digital Camera
    Kodak z760 lcd screen will not work in the auto
    It could have something to do with the batteries/ battery compartment: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
    Jan 14, 2010 | Kodak EasyShare Z760 Digital Camera
    Sdhc memory card won't format on my Z760 camera
    SDHC cards will not work with this model...sorry
    May 20, 2009 | Kodak EasyShare Z760 Digital Camera
    Charging...Red Light
    This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
    Oct 05, 2008 | Kodak EasyShare Z760 Digital Camera
    Battery door will not lock
    I had the same problem. The cause was the looseninjg of the plastic clamp at the top. I stuck a a piece of paper (thick) on the side of the battery to stop its slide upward. It works fine. The tape may not hold the battery fast enough.
    Dec 14, 2007 | Kodak EasyShare Z760 Digital Camera
    Kodak EasyShare Z760 Digital Camera Logo
    122 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
