Question about Canon PowerShot SX100 IS Digital Camera
Lens problem when pressing on the on button it just comes up lens error, restart camera then turns off !
  • Canon Master
  • 4,738 Answers
That's a fairly new camera, and is likely still under warranty. Contact Canon first to see if they'll help 1-800-828-4040 or 1-800-OK-CANON (1-800-652-2666).
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or Canon will not help, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Apr 06, 2008
I'm on my third SX100 in 6 months with the "lens error - restart camera" problem. I have had no unusual handling or location (dusty, sandy, etc) situations. Just regular family, flowers, landscape shots. My suggestion is that you take the camera back if you can and get a new one that is not a Canon. Seems they are becoming notorious for lens problems in this class of camera. I'm taking my third one that broke down this weekend (at a wedding) back to Best buy today, where I bought it , and demanding at least an in-store credit. This is ridiculous.
Posted on Jun 10, 2008
4 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
t00nz
  • 4738 Answers
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Mar 20, 2010
  • 11967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 25, 2010
My Canon camera turns it self off when I press the start button. the lens comes out & then the camera shuts down. When I restart it the lens retracts 3/4 & then comes right out & shuts down again. the lens...
hi, the camera must also be giving a lens error and must be making a whirring sound when turned on, hold the camera with camera off bang it with flat of hand , a few times , if this does not work , repeat it with camera on, even if this does not, when turning the camera on gently apply pressure on the front of the lens, do this just once , all the above fails , camera has to be service , lens unit may have to be changed
Aug 27, 2016 | Canon Cameras
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Lens error; restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
My camera will not come on when pressing on
Hi there some how your camera lend guide pin is damaged & thats why its not came out. For safety reason the camera auto off after pressing the power button. Thanks & waiting for your feedback.
Example image
Mar 23, 2010 | Cameras
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
Jul 28, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
121 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
