Question about Intel Motherboard
Intel Desktop Board D865GBF starts up as soon as I turn on the UPS
I have updated the bios and checked the settings in bios to make sure they are correct and made sure the connections where correct on the header where the power button connects. I have checked the battery on the board to make sure it is good condition and still it powers up when I turn on the UPS without touching the power button on the tower. I have now rigged up another power switch and still have the same problem when I turn on the UPS. When I shut down the computer and don`t turn off the UPS it is fine I can restart using the power button no problem. You have any other suggestions?
Flyer2
  • Flyer933 Apr 06, 2008
    What do you mean revert the switch?
    flyer2
    OK. I did that and got same problem. I don`t have another power supply to check to see if that could be the problem but I doubt that it is it anyway. Thanks for your input, You got any other ideas? Iam fresh out.
  • 655 Answers
Flyer2,
try to revert the switch connection on the board.
Thanks
Iqbal
Posted on Apr 06, 2008
  • Iqbal Husain
    Iqbal Husain Apr 06, 2008
    not switch flayer2 i said switch connection
    From front panel the two wires goes (from front panel power switch to your main board). ok.. just inter change these two wires connections. Suppose you have two wires for panel switch one white and other green and you have connected white to PIN1 and green to PIN2 on the board.
    Now try to connect white to PIN2 and green to PIN1.
    Thanks
    Iqbal
  • Iqbal Husain
    flayer i had the same mistake after changing i got it fixed.
    Thanks for your feedback
    Iqbal
6ya staff
SOURCE:
D865GBF AAC25827-409 win 7
Hello here are the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+865+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D865GBF
But here is no drivers for win 7.
Try to use windows update, for drivers missing.
If you are looking for the driver for the sound, buy a sound card to install on the mainboard.
Just make sure the driver is available, for the windows system.
Good luck
Jan 19, 2013 | Intel D865GBF Motherboard
Intel desktop d865gbf working in good condition .when i update bios did not boot and no display.
same problem as mine too.. the reason is you installed a wrong bios update program in your motherboard.. the thing i do is buy the exact brand and model of the bios of my motherboard. its easy to replaced.
Jun 30, 2011 | Intel D865GBF Motherboard
I am facing problem regarding BIOS, Therefore i want to update BIOS, My bord is Intel Desktop Board D865GBF/D865PERC. Please advice me to get free download
Go to the Intel site and enter the required details
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22bios+download%22
Jun 16, 2010 | Intel D865GBF Motherboard
D865gbf intel motherboard sata hdd compatibility
Check with Intel ... www.intel.com/support ... look up your board, specs, and it will tell you what you can and cannot use.
May 03, 2010 | Intel D865GBF Motherboard
IntelD865GBF starts up displays Blue INtel Desktop
remove Bios battery ..and try again ...probably it doesn't see something ...but its a good sign that the Intel blue appears
Nov 08, 2009 | Intel D865GBF Motherboard
I am not able to install sound driver. when i check in bios settings there is no sound option for disable and enable.
check under onboard chip. but if you motherboard doesn't have sound device most likely there is no option on it, if you plug a soundcard into your motherboard it will detect itself as your windows starts. there install the driver.
Sep 29, 2009 | Intel D865GBF Motherboard
Intel Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
