Nakamichi BX-2 Cassette Deck Takeup Reel
Takeup reel on Nakamichi BX2 Cassette Deck will not take up cassette tape and the deck will not play tape
  • sf_concerto Jan 24, 2009
    it only plays for about 2 seconds and it stops the counter is not functioning its stuck to 0000 reading. I already replaced the idler wheel rubber.
  • 4 Answers
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Posted on Aug 31, 2009
  • 1,142 Answers
It seems to be a hardware issue please go through this manual this will help you resolve the issue.
Posted on Apr 06, 2008
How do I get this device to play and record again? I often clean the heads.
if one reuses the tape often, ive found that the tape stretches and no longer covers the entire record path (or play path) , i still have a few cassette and reel to reel decks that I still use , and since the tapes are hard to find now I keep reusing the tapes more and more 4 the same thing , I guess its been like in the past year ive seen this tape stretching thing happen now
Feb 04, 2016 | Sony TC WE435 Stereo Dual Cassette Deck...
I have a single cassette deck Philips DC 900 when you hit the play button,it plays for about 5 seconds then stops and head retracts. Belts have been replaced
It's not seeing the takeup reel turning.
Either the takeup reel isn't turning or the takeup reel sensor has malfunctioned.
Check the belt to the takeup reel by doing a fast forward.
Will it fast forward? and is the takeup reel spinning during playback?
Feb 27, 2011 | Audio Players & Recorders
Cassette deck plays without cassette, makes clicking noise
The fault is that the reel drive of the deck is not picking up the tape and so to avoid the tape to entangle it rejects. Try to load a different cassete and see it this loads. If not you have a bad belt in your set. you will need to remove and change the belt. Also check for the reel drive to see if there is any slackness in taking up the reel. Since there are reel sensors that act when the reel pulse does not come on rotation of the reel, the set shifts to the other side and then ejects. Open and check this out and I am sure you can sort this out. Good day
Jul 10, 2010 | Sony DTC-ZE700 Dual Cassette Deck
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Nakamichi BX2 will not take-up tape and play
This may be a reel sensor problem, or the rotation of one of the reels is stopping for some reason. Most of the time, these faults are mechanical. There can be worn belts, or drive wheels, or gears, and etc. Sometimes there are faults in the electronics where a sensor is not being read properly.
The unit should be properly checked to evaluate the fault.
Jerry G.
Apr 06, 2008 | Nakamichi AV-10 Receiver
Cassette tapes
try firmly banging the cassette onto a table top(with reels flat) a few times, then ff right through and rew a couple of times. this will layer the tape more evenly and hopefully allow the mechanism to play it. the takeup reel or autostop mechanism may be failing if the deck does not have enough torque to carry the tape and may require belts replaced or dried grease removed in the transport.
Dec 07, 2007 | Tascam 202MKII Single Dual Cassette Deck
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
1,674 people viewed this question
