My tv keeps turning off. Sometimes I can turn it back on and it will work for awhile, other times it will turn off immediately.
  • 8,617 Answers
Your TV is going into protective shutdown most likely. Does the led blink when it shuts down? What is the model number of your set?
Posted on Apr 06, 2008
SOURCE:
I had a bad storm and the TV turned off. When I went to turn back on, I couldn't turn the TV back on with my remote. So I turned on by hand it immediately would turn off by itself after 2 seconds every...
It appears that there may have been a power surge or something that damaged the electronics of your set and cause it to work the way it is now. You might want to try replacing the power supply since it is the first area that would have a surge go through it and sustain the damage.
Aug 24, 2017 | Televison & Video
Tv keeps turning off
This is probably due to failing PSU capacitors. It is fixable.
May 19, 2014 | Televison & Video
TV turns of after watching
Check if the Auto turn off Timer is on
Apr 15, 2010 | Panasonic CT-27SF25 27" TV
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Plasma TV keeps turning off and blinks 5 times
Bad capacitors on the power board. If they look swollen or enlarged then they are most likely not holding enough charge.
May 17, 2017 | Televison & Video
TV Turns off on its own
Just keep smack'in it around, it works for me. It is the 'protection overload circuit' taking over and shutting the TV set off. This is because it detected a short or near-short circuit somewhere. Most common is high voltage, deflection amplifiers and main power supply. It's pretty much a common fix for an experienced tv repairman. It might set me back in the ballpark of $200 - $300.
Jul 03, 2007 | Sylvania SRT4127P TV
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Ekse
