Question about Lexmark Office Equipment & Supplies
Lexmark X7350 just quit
My Lexmark X7350 in the display area has black bars in the display. I tried turning it off and unplugging everything from it and then plugging everything back in and turning it on but nothing changes. I tried printing to it but the job just stays in the print queue. What do you think the problem is?
Hmm, that's a generic problem for Canon printers too. It can be a symptom of a burned out printhead. Remove the ink cartridges (and the print head if it is a separate unit). Look for evidence of burned/melted circuit traces. This is obvious on some Canon printheads; not so easy to see on the HP ink cartridges with built-in printheads. Either way, you should know that many printers are designed to "zap" the printheads with a high current pulse that gradually destroys the printhead circuitry. This is to keep you coming back for more (and prevent you from endlessly refilling those cartridges with built-in printheads).
Posted on Jul 29, 2008
SOURCE:
Lexmark x7350 vibrates and wont print
Hi
Try unplugging it from the power supply and leaving it as such for a while.
Check through the paper paths for any obstructions.
Clear any print queues.
Mar 02, 2012 | Lexmark X7350 All-In-One InkJet Printer
Hardware problem - papersensor x7350 create paperjam
There could be something blocking the paper path or maybe the printer just needs to be reset. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges from the carrier. While the cover is open, check for any foreign objects blocking the cartridge carrier's path and the paper path. If cartridge area is clear, close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert your cartridges. Load some paper (avoid overloading). Try to print again. If paper jam continues, then perhaps it's a mechanical problem. Please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X7350 InkJet Printer
When I print pictures, they print with a pink tint. But when printing text, it comes out black/normal. How can I get rid of the pink tint?
Try to the clean the nozzles of your color cartridge. Refer to this article in the Lexmark website on How to Clean the Print Cartridge Nozzles with the Lexmark X7350. If problem continues, try to insert a different known working cartridge to deternine if your color cartridge is faulty.
Feb 16, 2011 | Lexmark X7350 All-In-One InkJet Printer
Scan light/bar will not move. It seems to be "stuck" It does light up, top feed vibrates but will not feed. Print command from screen works and unit prints
If making a copy on the printer does the same thing, it's a hardware problem in the copier/scanner area. You can try turning off the printer then powering it back on after 30 seconds. Make sure the printer is plugged in straight to the power outlet in the wall, bypass any surge device or power strip. If problem persists, I strongly suggest you contact Lexmark technical support to further investigate the problem.
Aug 10, 2010 | Lexmark X7350 All-In-One InkJet Printer
Only displays bars when you power up`
No surge protector is going to stop a lightning strike. It's just way too powerful.
1. Make sure you've unplugged, waited 10 seconds, plugged it back in. That's more than the on/off button does.
2. If your PC will communicate with the printer at all, Lexmark has a program that will reset it. It's located here: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:520:0:0&docid=ENUS25837
Steve
Sep 11, 2008 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X7350 alignment problem
you can check the old cartridge for reference
May 19, 2008 | Lexmark X6170 All-In-One InkJet Printer
AM/PM firmware problem on X7350 printer
here's an idea..the printer doesn't know what time it is, so maybe it's Hawaiian...just kidding...do you have the user manual on this puppy?
Mar 21, 2008 | Lexmark X7350 All-In-One InkJet Printer
New Lexmark X7350
This is not normal take it back to the store.
Feb 24, 2008 | Lexmark X7350 All-In-One InkJet Printer
Open Questions:
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
