Ecoquest Fresh Air Living Air Purifier
Problem for Ecoquest Fresh Air Living Air Purifier
Unit won't turn on
By ttamblynn on Apr 06, 2008
I have a Fresh Air unit. I cleaned the unit and after I was finished it won't turn on at all. I did notice when I was 1st unplugging the unit the plug was kind of hard to pull out of the back of the unit.
I verified the fuse and power cord are okay. The activator clip is depressed.
What else can I check?? It's only about 2 years old.
Thank you for any help!
Kim
Popular Solutions for Ecoquest Fresh Air Living Air
Questions and Unsolved Problems for Ecoquest Fresh Air Living Air
Do you recommend Ecoquest Fresh Air Living Air Purifier?
Answer
Answer
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several... (More)
Answer
Ecoquest Fresh Air was left in a car running for two hrs with heater on, when we returned machine... (More)
Answer
my eco quest fresh air turns on and off continuously
Answer
I have two identical units and I have swapped every removeable/replaceable part including cord and... (More)
Answer
I replaced the purifier plate, but the purifier will only briefly come on for 1-3 seconds then it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Fresh Air Living Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2543
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
