Question about Mitsubishi WS-73905 73" Rear Projection Television
Blinking tv I have a 73" mitsubishi projection. It seems when my house is below 70 degrees my tv will not turn on for hours. Is there a way to speed up this process?
  • Mitsubishi Master
  • 8,617 Answers
That model has some bad capacitors that will cause this. Does the power light constantly blink when it wont start? If so change the (4) 1000uf capacitors on the DM board this should solve the problem
Posted on Apr 06, 2008
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I had to turn the main breaker to my house off to do some repair. When I turned the breaker on, the power light was blinking like it normally does. However, I have not been able to power on the TV. What is...
You are the victim of 4 leaky capacitors on the DM assembly, that's the vertical board all the way to the left looking from the rear of the unit. Replacement of the 4 capacitors (1000mf @ 25v, 105 degree) will restore the TV. As always, at plug-in the TV will blink for up to 70 seconds during the boot-up sequence so make sure to allow for this time. Good luck!
Bill W
integrityhomeworx.com
Mar 14, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a Mitsubishi 73" TV model number WD-73735.
Try replacing the thermal sensor. Located behind lamp in lamp housing shroud.
Jan 18, 2011 | Mitsubishi Televison & Video
Turns off
No I do not have an answer yet
May 19, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Green Light on the front flashing
Needs DM module repair = replace four 1000mf/25v 105 degree
caps..www.chrisandnat.com/projects/blinkingtv/blink.htm
.......................T.
Feb 07, 2008 | Mitsubishi WS-73713 73" Rear Projection...
73" rear projection Mitsubishi TV
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Sep 05, 2007 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi WS-73905 73" Rear Projection Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
