Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool Gold Dishwasher not moving water
My Whirlpool Gold built in dishwasher purchased 12/2002 pumps water into the machine but that's it. It will drain when I press the cancel button. It has been very noisy the last few times we ran it, but there is no water leaking anywhere.
The model number is worn off the paper label but I have the serial number FM4309573. I suspect the pump.
  • 413 Answers
The wash motor has probably froze up.
Posted on May 29, 2008
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 31, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold built in dishwasher fills, lights are on but does not spray water or drain.
This is a possible sign that the water pump has failed in some way or the control circuit for the water pump has failed. You MIGHT be able to access the pump without pulling the dishwasher out of the cabinet space through the front kick panel. You may have to remove a few screws to get it off. You'll have to work low, on your belly, but it'll beat taking the dishwasher out and turning it on its side. Especially considering it's probably still full of water!
With the machine on and "running" at the point where it's supposed to be spraying or draining, check for voltage at the pump. If you see 120V there, the pump motor has failed. If you don't see any voltage, the control board assembly has most likely failed in some way. It's located at the top of the door. Again, remove a few screws and tilt it out. I would first check for a blown fuse, burnt board, etc.
I hope this helps! :) Let me know if you need any further assistance in this matter.
Feb 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water does not drain out completely on our model GU1500 Whirlpool Gold dishwasher. This happens about every 4th time we run it. Water is cloudy and about 2" deep in bottom after cycle ends.
there is a PROBLEM with the pump.it is most likely clogged,in which case,it must be removed and cleaned.the pump might also be faulty,and so must be replaced.
Oct 24, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish washer fills and then drians without washing
If you're sure it is heating the water, then it sounds like the wash motor/pump has failed. If you've worked on washing machines and/or dish washers before, this is potentialy a DIY job - the Haynes Dishwasher manual is very good, and parts can be found on the internet.
The reason for cheking it is actually heating the water is that the symptoms sound very similar to those of a failed heater = fill, pause, empty, stop usually accompanied wth an error code. Error code will be presented by a number of flashes of a lamp, or a number on a display panle depending whch machine you've got.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Water remains in Whirpool Gold Quiet Partner dishwasher
sounds like an issue with the drain pump, disconnecting the drain hose fromm the trap and run the unit, pointing the disconnected drain hose into a bucket. You should get a fairly strong stream of water until most of the unit has drained, if not you either have a blockage or ,with the grinding sound, a bad pump.
Mar 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher, whirlpool generation 2000+
not enough info. new house? newly purchased house? new dishwasher? newly installed?
check to see if water line was connected
see if a valve has been inserted in water line and is open
if fools day joke, thanks for my time.
Apr 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
673 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
