Question about Uniden Cordless Phone
Charger light the charger light will not quit blinking,if i pick up the phone it will guit if i turn on the phone.when i put the phone back on the cradle it will start blinking again
The red light on the base of my Uniden DXI8560 will not stop blinking. It stops while I am on the phone. When I hang the phone up, it starts blinking again. What do I do?
Posted on Sep 10, 2008
I had this same problem and all I did was to unplug the DC adapter at the phone and plug it back in after a few seconds. The solid charge light came on immediately, like usual. I let the battery charge for several hours before using the handset again.
Posted on Apr 26, 2008
Binatone bb200
I've had exactly the same problem. The connector that plugs into the docking cradle (or phone if you don't use the cradle) is faulty. Mine had a short circuit. Try gently moving the cable closest to the connector. Alternatively, turn off the charger at the mains socket, leave for 10 minutes or so then switch back on. If that doesn't prove it and you're lucky enough to have another charger, try that to see if the original is at fault.
Be warned that even though it's a 5.2V charger and a common USB type should work, getting hold of the identical USB connecting cable I found impossible. I had no luck sourcing a replacement Binatone charger either.
In the end I removed the sticker from the base of the cradle revealing the screw then undid it to dismantle the cradle. The cradle is very simple so don't worry. I cut the USB plug off the charger, bared & tinned the wires then soldered them directly to the docking contacts (wire with feint white broken line is +5V and should go to CH- solder pad, the plain black 0V wire goes to CH+). You'll have to cut a small notch in the lower edge of the cradle to pass the wires through before reassembly.
The soldering's very easy but don't overheat the pads otherwise the contacts will fall off which might be tricky to reposition. I'm quite handy with a soldering iron but if you're not, it's only a 5 minute job for anyone that's competent.
Jun 19, 2013 | Cell Phones
Cant get it to turn on, it wont charge right. I put it on the charger, red light blinks and then stops. It will turn on, then right back off
Plug your phone in the charger and then take out the battery and put it back in. Or you can push the button to turn your phone on and then plug it in while it is starting up and it should catch on and start charging. It is definitely an annoying glitch, but a simple solution
Oct 12, 2009 | LG Incite Cell Phone
Green light on charging cradle is blinking green and mouse does not work
charger cradle lights are both on- when I pur mouse in charger lights on mouse do not come on.
Aug 12, 2009 | Computers & Internet
Plugged my cordless GE phone into phone jack "A"
You dont owe me anything dear.
If your phone is working properly. Charging, incoming call and outbound are ok then you are safe.
Blinking light is called heart beat. It tells you that system is working. Let us know if you need something else
Have a great evening.
Vit
Jun 21, 2009 | GE 27998GE6 Cordless Phone
When charging my axim X30 on the cradle, the on-off light is blinking from green light to amber consistantly... when I remove the device from cradle the device does not turn on at all.. I have replaced the...
It sounds to me that your "original" battery, the one that causes the blinking when charging is completly drained dead, causing it to show an error by blinking the light.
I have one of these PDA's and have never had that problem, I also have a larger battery as well, and it works great. I suggest recycling the other battery, and possibly purchasing another larger one for back up,
Mar 27, 2009 | Dell Axim X30 Pocket PC
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Exlim z750 not working at all after putting it on charger
I would say the first thing to check would be the charger. If no lights came on it that would be my guess.
Jun 09, 2008 | Casio Exilim EX-Z750 Digital Camera
Troubleshooting.
Blinking light means charging error. Call tech support and they will replace battery for you for free.
Nov 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Uniden Cordless Phone Logo
1,183 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
