Question about Hyun Won mobiBLU DAH-1900 MP3 Player
Mobiblue DAH-1900 mp3 player
When i reset it...(NO FORMAT pops up always)..i try to format it through usb but it always disconnect and then connect....i cannot use it anymore now
  • Anonymous Aug 12, 2008
    I CANT PUT POWER ON.WHEN U PRESS POWER BUTTON ONLY BLUE LIGHT AROUND THE CURSOR BUTTON COMES ON TILL U KEEP
    BUTTTON PRESSED,BEFORE FEW DAYS IT USED TO SHOW NO FORMAT ALL THE TIME WHEN U PRESS POWER ON.
    I TRIED TO UPGRDE FIRMWARE BUT INSTRUCTIONS ARE NOT VERY CLEAR,LIKE WHER TO PUT THE HOLD SW. & WHAT IS THE FUNCTION OF SMALL SW NEAR THE USB OUT TERMINAL.& WHAT IS RECOVERY
    Problem Solver:
  • 6 Answers
Downloader the firmware updater from the mobiblu site
Install the software, connect the player via the USB cable, set the switch to hold and run the updater. When it is finished, stop the device and disconnect it. When you power up, it will be back to factory settings (any data/music will be erased).
Posted on Feb 26, 2009
    New Friend:
If the above does not work then you can try what i did that fixed the issue. I clicked on the drive it was connected to and windows said the drive was not formatted.. so i did the format,, the quick format.. and it fixed it... maybe not the quick format if that does not work.. oh with the quick format i did not lose any songs.. i can not explain it
Posted on Mar 04, 2010
  • Laurent Locke Oct 24, 2011
    Tried it under Vista and it unblocked the player but I did lose all my music. Still, better than a new paperweight!
I had the same problem just go to http://www.advancedmp3players.co.uk/forum/index.php?showtopic=7375 and download this, it worked for me.
Posted on Jul 17, 2008
SOURCE:
I need the original installation cd software that came withe mobiblu cube dah-1500i
Here is the cd software.
Here for all the available files for the mobiblu cube dah-1500i from the manufacturer.
Use google translate to understand what they mean.
Mar 03, 2011 | Hyun Won Cube Blue (1 GB) MP3 Player
USB port is not recognized
Have you tried a different cable? Many players happen to come with dodgy USB cords.
Jun 26, 2009 | Hyun Won mobiBLU DAH-1500 MP3 Player
Mobiblu DAH 1500i Battery
I formatted it with windows 7 and it read "no file" even with songs on it. Then I formatted it with windows XP and it worked!
Mar 18, 2009 | Hyun Won mobiBLU DAH-1700 (512 MB) MP3...
CANT TURN POWER ON
Download the firmware updater from the mobiblu site
Aug 12, 2008 | Hyun Won mobiBLU DAH-1900 MP3 Player
Hanging
The reset switch has to be operated using a pin or paper clip. There is a small hole beside the USB socket. If it keeps happening update the software as follows.
Feb 20, 2008 | Hyun Won mobiBLU DAH-1900 MP3 Player
System error
TPeter 1/14/08
mobiBLU has a "software fix" for this problem. I had the same thing happen to my player. I had to return the machine to them. When I received the machine back, they said that I could have downloaded a program from them. So I went to their site and did. When I returned my player to mobiBLU, they had it for only about 3 hours and put it back in the mail! I shipped it USPS with a "confirmation Return Receipt". It showed delivery at 12:34 PM..and the Return E-mail from them was dated (same day) at 2:57 PM. PRETTY FAST..HUH! I have the Program in my computer. It came zipped. I opened it and ran it. Fixed the problem right off. You can call mobi BLU and I am sure they will e-mail you the program. It is only 2.22 MB. The program IS:
Firmware file version 4.0.100.1190 It even says **SYSTEM ERROR FIX** DAH-1900 Updater M110 060424.exe This Updater Program also has all the "PODDER" stuff on it too! I don't know enough about my computer or I would E-mail it to you!
Good Luck
[email protected]
Jan 14, 2008 | Hyun Won mobiBLU DAH-1900 MP3 Player
MobiBLU DAH1500 errors when plugged in with Skylark device found
I had something similar with my Cube. WinXP pro would detect it a an unknown USB device. Sometimes when I would manipulate the USB cable, it would detect correctly. To make a long story short, it turned out the be the USB cable. When I tried a different one, everything worked correctly. Hope this helps.
Sep 13, 2007 | Hyun Won mobiBLU DAH-1500 MP3 Player
"no file" message that won't go away
verify the files using your pc. try placing them on the root (no folders).
Sep 13, 2007 | Hyun Won mobiBLU DAH-1500i (2 GB) MP3...
HELP
FYI, my mobiBLU DAH-1500i 1GB unit wouldn't boot. It would start up the musical note logo and stay there. I had to hard-boot it with the little reset button. Then I connected the USB cable and "unloaded" all files, then used Windows to FORMAT the drive (FAT32). After that it fired right up and works fine. I might try to update or reinstall the firmware if it doesn't keep working. Good luck.
Sep 20, 2006 | Hyun Won mobiBLU DAH-1500 MP3 Player
Hyun Won mobiBLU DAH-1900 MP3 Player Logo
532 people viewed this question
Top Hyun Won Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Hyun Won Audio Player and Recorder Expert? Answer questions, earn points and help others
