Question about RCA 27F650T 27" TV
No sound on my RCA 27F650T
Hi, I have an RCA 27F650T and turned it and no sound.  Unplugged Verizon FIOS to see if I could get some static sound--nothing.  All the various things are plugged in correctly and checked the TV menu options, all ok.  Oh and the mute is not on...HELPPPPPPPP
  • zimbobsteven Aug 20, 2008
    i dont know what is wrong there is no sound coming out of my 14" truflat rca, its hella gay, i dont know alot about tvs, so can you pleeeeeese help!!!!!!!!!!!
Yea I had that problem one day as well.. all you got to do is go into the menu settings and check the box for the Int speakers... that should do it
Posted on Dec 12, 2008
What is the Brand Code for this TV?
The brand code should be listed in the Verizon FIOS remote user guide.
Jul 30, 2014 | RCA Televison & Video
The prior owner of my house had verizon fios, the fios wiring is in basement as well as junction box for telephone (gray box) I have unplugged the ac power plug to the fios as I am not using their service....
you're better off calling verizon to remove it.
but no, it uses your power ... not anything from the street. fiber optic cable is made of glass and does not conduct electricity.
Jan 22, 2011 | Lands Phones
No sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
Apr 29, 2010 | Vizio L37 Television
Cannot program Verizon FIOS remote with RCA L32HD31 32 in. HDTV LCD TV, none of the codes work. Can you assist?
Talk to Verizon,should not require code because u using verizon remote on verzon box.
Jan 15, 2010 | RCA L32HD31 32 in. LCD HDTV
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Picture goes bad when playing Verizon Fios DVR or On Demand
I had issues when I set an SD override for the box, it would sometimes display as bad input when switching to HD content(as well as display all menus in SD even with HD mode in settings.) Turning that off in settings (also turned off "modes" which has no description) stopped it and gave me guide/menus in HD.
Apr 04, 2009 | Sharp Televison & Video
RCA tv with FiOs
my fiance fixed it. he has this really expensive remote that he programmed via a USB port and some fancy fingerwork that I can't even begin to explain :D and I was able to change the channel back to 00
Jan 20, 2009 | Televison & Video
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Apr 09, 2008 | RCA F27625 27" TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
RCA 27F650T 27" TV Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
