Question about LG KF600 3MP InteractPad Triband Phone Silver w/1GB
LG kf600 software on the pc doesn't see the connection with the phone, but the pc does
  • 12 more comments
  • toxa Jun 30, 2008
    I have the same problem and whant the solution :(
  • chazreeve Jul 30, 2008
    i have the same problem i can find the phone on my computer as a removable disk but on mobile sync i cant .. need solution
  • Anonymous Aug 09, 2008
    I also have the same problem. My pc recognises my kf600 but the software that came with my phone doesn't. Cannot synchronise. Has anyone got a sloution? Thanks
  • afvenegas Aug 29, 2008
    Phone internal and external memory is recognized as a Removable drive, but LG software does not recognize the USB connection.
    Steps so far:
    1. Check if you need to enable the connection on the phone - Nothing
    2. Check if you have a USB port conflict - Nothing
    3. Repair LG Original SW installation - Nothing
    4. Re-Install LG original SW - Nothing
  • matiass Oct 13, 2008
    its the same problem
  • yasminannuk Nov 30, 2008
    when i put music on my phone from my computer it says it has synced yet when i unplug my phone it is nowhere to be found where do i get the software for this i have vista and looked in the little manual and vista is not on the list
  • Anonymous Dec 22, 2008
    how do i transfer music to my kf600 from my computer
  • Anonymous Dec 28, 2008
    it only shows mems and messages it wont let me put music on there :(
  • ela93x Jan 10, 2009
    i have exactly the same problem :/
    but now it will connect, but i can tranfer photos/music.
    i can only play about with contacts and messages??
  • Anonymous Feb 20, 2009
    getting on my nerves its not working :(
  • littlangel Feb 25, 2009
    i bought my lg kf600 in black market and so i don't have driver to connect it to PC. Even if i connect it i can transfer picture and song successfully but they are unreadble in my cellphone
  • Anonymous Mar 25, 2009
    I have exactly the same problem :/
  • surfbob17 May 16, 2009
    I installed the CD given with the phone but the phone does not seem to connect therefore it is unable to read info off of my phone - for example phone numbers and messages but will let me transfer messages via USB
  • Anonymous May 17, 2009
    Software is not connecting to phone. in addition when i try to connect through my computer i have a window appears which when you click on solve problem de-installs software, Thanks, Lizzie
I have successfully install some applications on LG KF600.
0. Install application - LG Mobile Sync (to verify the driver in Control panel- system- Hardwave Device- Modem- LGXXX). If it did not show up, well it is normal. You may need to restart PC after installaion.
1. Select the USB conection (for LG KF600) from the connectivity option
2. Connect USB cable (connect to PC first) from PC to USB port of LG KF600.
NOte : your will see "portable disk" on your phone.
If you did not see it. Please stop.
3.Check My computer (from PC). Is there any NEW Removeable device appear ? Unplug and plug again from the phone and you will see it.
4. In your Removealbe device (phone), you will see 5 folder (actualy from Phone -My Stuff )
5.Copy files from PC to desired folder (phone).
Does anyone know where to get the english dictionary for LG KF600 ?
Sincerely.
Posted on Sep 01, 2008
DONDE CONSIGO EL SOFWARE DEL LG KF 600
Posted on Dec 02, 2008
How can i transder themes to lg kf 600
Posted on Jul 21, 2008
Hi, guys! All you have to do is to format you Micro SD from YOUR OWN mobile phone Lg KF 600, then it will make it according to it's own needs after that you will be able to connect it with USB (like hard drive & NOT sync!!) and to put all you want. That's all.))
Posted on May 14, 2009
Can anyone let me know how to connect to internet through LG kf600. (ATT&T USA)
Posted on Apr 23, 2009
Well i had my sim in for the 1st time and it worked wen i took it out an tried it didnt and wen i put it back in it worked lol so i hope it helps becuz i spent 2 hrz findin a solution and den i just put my sim in n tried n it WORKED! xxx
Posted on Oct 13, 2008
If you wan to synchronise your phone with PC, you have to go to settings,connectivity, USB connection, and then select DATA SERVICE . when you did this, connect you phone and PC together via USB cable ! when you connect it, you WILL NOT see any notification from you phone regarding the connection. BUT you phone is connected ! open you saftware and click on connection. there should not be any problem there !
and of you just want to send media files , e.g. music, chose MASS STORAGE in USB CONNECTION.
Posted on Sep 04, 2008
erone47
  • 458 Answers
SOURCE: My pc is not reading my lg kf600 phone only charging battery,connected to pc thru usb cable.
You need to install the phone pc suite for the phone to communicate with the pc.
If your phone came with a CD, insert the CD to install the pc suite
Posted on Jan 02, 2010
Testimonial: "I do not have pc suite for the lg 600...now running a nokia 5200 which is more pc friendly. Thanks a lot though"
SOURCE: I just brought a LG
what shall i do
Posted on Dec 01, 2008
SOURCE: addomg music to LG KF600
i have the same problem with mine. for me it's easier to just connect through usb and not bother with the pc suit. this way you can access both external and internal folders. adding music is just easy as drag and drop
Posted on Jan 07, 2009
vishalkum506
SOURCE: Problem connecting to internet through LG KF600.. Please help!!!
go to message box type i am sexy i want someone to *******
SOURCE: require free call recorder software for LG KF600 with beeping sound
Recording a phone conversation without the knowledge and consent of both parties is generally illegal.
The beep is there to let the other party that the conversation is being recorded.
Posted on Jun 03, 2009
I WANT TO UPDATE MY LG KF600 MOBILE INTERNAL SOFTWARE UPDATE WHAT SHOULD I DO AS THE OLDER ONE IS POWER CONSUMING ALSO NOT INSTALLING INTERNAE SETTINGS SAYING MEMORY IS FULL, i have reset my phone many...
connect the phone to your PC. and open the phone software and then find a option inside that to update your phone software. generally all the phone softwares have it. while doing that make sure you dont disconnect the phone during installation.
Aug 03, 2009 | LG KF600 3MP InteractPad Triband Phone...
Uploading video from phone to pc
sir you may need video converter because the pc does not support 3gp file
Jun 06, 2009 | LG KF600 3MP InteractPad Triband Phone...
Require free call recorder software for LG KF600 with beeping sound
Apr 28, 2009 | LG KF600 3MP InteractPad Triband Phone...
My LG KF600 mobile phone on the orange network won't connect to the internet and my pay package gives me free internet. HELP!
menu>tools>browser>enter address e.g. google
this should work
instead of going straight to home ect
Good luck
Mar 11, 2009 | LG KF600 3MP InteractPad Triband Phone...
Addomg music to LG KF600
Nov 29, 2008 | LG KF600 3MP InteractPad Triband Phone...
LG KF600
good day ! you need bring your phone to the cellphone center to install the software for that ! ...good luck !..
Sep 10, 2008 | Cell Phones
LG KF600 3MP InteractPad Triband Phone Silver w/1GB Logo
9,093 people viewed this question
Top LG Cell Phones Experts
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
