Question about Karcher 2500 PSI Pressure Washer
Karcher pressure washer My Karcher pressure washer switches ON and OFF continually when I am trying to wash. It is about 6 yrs old 120 Bar 1750 PSI 420MH
3 Suggested Answers
  • 389 Answers
SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Posted on Apr 17, 2009
seanpwright
  • 2030 Answers
SOURCE: My Karcher 1750 psi electric pressure washer is
thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Posted on Apr 01, 2010
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Karcher k3.86 on/off switch does not work
If you are certain it is the switch, try looking on Ebay for a replacement switch.
Apr 16, 2014 | Karcher 1750 Psi Elec Pressure Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
I have a Karcher KB5050 it started to pulse when the trigger stopped
Is there water leaking from the bottom ? If so, then you have a leak in the pump. Bad seal or crack in the Pump.
If under 1 year old and have a receipt, Call Karcher for a warranty replacement.
May 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Jun 19, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
198 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
