We inadvertently changed the video output from YPbPr to RGB on our S VSR 25 Jamo system. We cannot access the setup menu to change it back and the screen is now showing Mode not Supported and we cannot see a DVD playing.
  • lynn739 Apr 06, 2008
    We have tried using a scart lead but that did not solve the problem, nor did turning the whole system on and off again. Any more ideas would be greatly appreciated.
  • lynn739 Apr 07, 2008
    Thank you for all your advice - a combination of your ideas and a night's sleep have solved the problem! Hooray! Will definitely use you again if we need to. Many thanks!
    Genius:
  • 1,665 Answers
Troubleshooting
If the S VSR 25 appears to be faulty, first consult this troubleshooting guide before calling for service.
Refer also to the corresponding instructions in this manual.
WARNING
Under no circumstances should you attempt to repair the system yourself.
http://www.google.gr/search?hl=el&rlz=1T4RNWN_en__241GR242&q=S+VSR+25+Jamo+system+troubleshooting&btnG=%CE%91%CE%BD%CE%B1%CE%B6%CE%AE%CF%84%CE%B7%CF%83%CE%B7&meta=
Posted on Apr 06, 2008
    Genius:
  • 3,422 Answers
HI,
You can try using S Video cable instead it will work.
Goodluck,
Please don't forget to rate the solution.
  • 1 more comment
  • Priya darshan Apr 06, 2008
    Please click HERE to get some usefull info.
    HI,
    Please click HERE and check this out also i believe this will solve your problem.
  • Priya darshan Apr 07, 2008
    Can you please tell then whoose solution was more appropriate?
  • 3,037 Answers
Try resetting the system, you can most likely just unplug it and it will reset. Let me know if you need further help. Thank you and have a good day.
    Genius:
  • 1,142 Answers
Can u tell me what settings did u change exactly
  • Televison & ... Master
  • 19,396 Answers
Which is dvd make and model?
  • 2 more comments
  • Ginko
    Ginko Apr 06, 2008
    You will probably fix this problem using a scart cable to temporary connect to tv and restore the settings. Scart should work automatically with any setting.
  • Ginko
    Ginko Apr 06, 2008
    Connect the dvd to a different tv set using scart, it may depend on the tv.
  • Ginko
    Ginko Apr 06, 2008
    Try pressing “I/P SET” button on remote.
  • Ginko
    Ginko Apr 06, 2008
    If all the above does not work, here is the reset procedure :
    Open the disc tray
    Hold down STOP button on front panel
    while holding down “TOP MENU” button on
    remote. Be careful to point the
    remote at the Remote Control Sensor, and that the remote is working
    The TV screen now should displays software
    version.
    Turn the S VSR 25 OFF on the front
    panel and turn it back ON again after 10
    seconds.
    If you have the opportunity test the jamo on a different tv pressing pressing “I/P SET” on remote.
    If all the solutions do not work, there may be an additional problem than just video settings.
SOURCE:
Sony VPH D50Q projector doesn't see signals above 480i
HI Tom,
For some reason I cannot reply to other inquiry would you please close the problem, I am glad that the configurations worked out for you.
Al
In order to configure the proyector for hd video you would need to change a couple of things in your set up.
First you would need to use hd cables, and not the rgb. You can purchase some standard high def cables at any best buy or radioshack, depending on the source device there is the standard high def out, the set of 5 cables, 3 video plus the 2 audio.
To enable the unit to support the progressive DVD signal, perform the following
procedure.
Connect the DVD player’s component output into Input A.
In the SET SETTING menu select HDTV-YPbPr for Input A.
In the INPUT SETTING menu highlight Sync and select EXT (HV).
The IDTV module disables itself automatically
Perform this procedure with nothing connected to the component input on the projector, otherwise you will get the an off/on flickering screen which prevents you from seing what you are doing when navigating the menu screens. Perform the procedure and then connect.
Let me know if you need anything else,
Al
Aug 02, 2010 | Sony VPH D50HTU Multimedia Projector
Picture went to all pink but menu is in full color if bypass hd inputs picture is fine and using rca cables picture is fine its just the component connections that turn screen all pink
Your output device is likely trying to send out a YPbPr signal. On the output device try switching it to an automatic mode ideally or manually switching it to RGB. On the PS3 it is under the Video Settings section (Not the display settings.)
Jul 20, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
How to change the video output on denon avr 486-I have 3 devices using the component video inputs (playstation 2, xbox 360 and a dvd player) but i have an analog video output going to my tv. my devices are...
under the system setup menu go to video setup, and re assign the devices, then make sure the video output is assiggned to component as well. That should give you what you need
Jul 16, 2009 | Denon AVR-687
I HAVE A LG DVD MODEL DSI 8556P FROM THE VIDEO OUTPUT I CANNOT GET THE SIGNAL BUT FROM COMPONENT OUT I CAN RECEIVE SOMEONE SAY ITS THE CODE YOU NEED TO CHANGE
some times setup settings get change automatically for video default it is rgb but may be due to some stupid bug ib firmware what u need to do is connect through your comp monitor or through cpoixeal cable and then go to setup video setting change it to rgb signal ( not sure about exact menu name )
hmmm
Apr 20, 2009 | LG DE9523P DVD Player
Re-set 'Video Setup Page' in Main Setup Menu
hi kevin, just did the same thing, have u figured it out yet?
thanks
tim
Dec 20, 2008 | Audio Players & Recorders
PS2 on a LCD
You will need to go to your PS2 system configuration screen and change from RGB to YPbPr component video output. The 1920ex (remember to switch source to YPbPr) will then correctly recognise the signal from PS2.
Hope this helps you. I am also a 1920ex user.
Apr 16, 2008 | Sony PlayStation 2 Slimline Console
Sky not working properly on my samsung lcd tv
This is likely to be caused by the changing of the screen mode between ads and or programs, by your TV.
If so, changing the Sky output to 16:9 will fix it.
Press [Services]
Select option 4 - System Setup
Select option 1 - Picture Settings
Change "Location 1" TV setting to 16:9 (This will make the Sky box handle any changes and give you a permanent widescreen output to your TV. This is the recommended setting for widescreen TVs, but sadly, few Sky installers bother to do it.
You can also change "Location 2" if you have a second widescreen TV connected in another room.
Whilst in this menu change the Video Output to RGB from PAL (If not set already) RGB gives a much more stable picture (particularly on the menu system)
Go to Save new settings and press [Select]
Exit the menu system, and you problem should be solved.
Feb 20, 2008 | Televison & Video
Connecting component video YPbPr to TV with BNC port for RGBHV
No, this will not work. Picture will roll vertically. Originally they intended for HDTV to be red,green, blue, & Horizontal, Vertical sync. That changed after the first generation mitsubishi's.
In the service menu you can change the settings for the HDTV Input. Try that first by "Hitting menu button followed by 1259" or menu 1257. Let me know how that works for you, If you need a different code for service menu...contact me again and i will look it up for you. But the answer to your question is you can make it work or you can purchase a 300.00 box that will allow you to switch to that input thru..mitsubishi.tv.com
Good luck and keep me posted. GURU JAY
Dec 08, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Ekse
