Question about RCA D61W20 61" Rear Projection Television
D61W20 RCA, Red Screen and then shuts down
I have a RCA D61W20 it the screen went red and then it shots off
  • RCA Master
  • 8,617 Answers
Sounds like the Red CRT (tube) has shorted. You can test by removing the RED crt circuit from the end of the RED tube and making sure it isnt touching anything try powering up the set. If it comes on and doesnt shut down the red tube is the problem and will need to be replaced . expensive part to replace the Red XRT will be over 300 and at least 2-3 hundred to have it installed unless you know someone who can replace it for you.
Posted on Apr 06, 2008
Rca hd 52w66 has red screen then shuts off
The red CRT has shorted. You can get the RCA Red Projection CRT from www.tvrepairworld.com
Jun 30, 2012 | RCA HD52W59 HDTV Projection Television
The screen has turned completely red. There is no picture at all. Please tell me what I can do to fix the problem?
You have a bad optical engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains how to remove and replace the light engine and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
May 19, 2010 | RCA D61W20 61" Rear Projection Television
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
RCA D61W20, Rodent Urine, STain in the middle
a red screen with thin white lines are retrace lines which is often a sign of CRT failure. Try unplugging the red crt PCboard and making certain its not touching anything then power on your et if it doesnt shut down you will know the trouble is in the red CRT and will need to be replaced.
Apr 07, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61, power on and off, Rodent Urine.
it may just be where the blue and green CRTs were over driven when the red flared. This may go away in a few days on its own .
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Rca d61w130yx1 61 rear projection
these rca sets have a processor that will shut it down it has a problem. red screen indicates yes.. it possible a red crt...difficult to replace. and expensive if not under warrenty. around 200 just for crt plus labor.... sorry
Apr 28, 2007 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
