Question about 2wire (1000-000057-000) Modem
2wire modem home network
Problem # 1 - when i click on home network view network summary then click on view internet access control under internet access restriction schedule 1 select a computer where the drop down arrow is all my previous computer names are still listed there how do i remove or delete them ?
problem # 2 - the same thing under edit advance network settings when i click on edit address allocation it shows the list of DHCP Devices which are no longer in use which are the same computer names as problem # 1 how do purge it ?
  • Anonymous Nov 16, 2008
    I have the same problem but don't know the MDC password.
    Is there a default password. I just got the 2wire few weeks ago.
    help please
    Scholar:
  • 53 Answers
Go to homeportal/management, or gateway.2wire.net/mdc. on the management and diagnostic console, under troubleshooting, click on resets. then click on the clear button for local network to erase all the devices on the local network. go to device list under local network, make sure you only have the computer or device seen on your device list aside from system.
Posted on Apr 08, 2008
How do i setup my 2 wire router with dsl modem to network iat home
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
Http://192.168.1.254/ has been put into my home page browser but nothing happens
IP ADDRESS 192.168.1.254 is the default gateway of an AT&T modem router (RESIDENTIAL GATEWAY) (2WIRE). for this ip address should be able to view the main screen of your 2wire modem and if not your computer is connected to a different network.
1) try connecting the computer to the 2wire RG using a ETHERNET cable (if your connected via wireless)
2) make sure that the DSL light is solid and not blinking.
3) if your computer already connected by a ETHERNET cable, try accessing the same ip address if your able to view the main screen of your 2wire modem it means that your computer will be able to connect to the internet.
4) try this also:
this for internet explorer:
click tools - connections - LAN settings
( if there's a tick mark on PROXY SERVER remove it )
if you do have tick mark on PROXY SERVER then your computer have a virus, because virus can put a tick on PROXY SERVER without you noticing it.
after removing the tick you will be able to connect to the internet again.
Apr 10, 2011 | Computers & Internet
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
Where and how do i find my access point I'am trying to set up a wireless internet connection
Hi Kregerbc,
If you want to know your Access Point it is the Name of your Network or Network Key (SSID). Usually the Network Name of 2wire router is 2WIRE and the Last 3 digits of the Serial Number of the Router. The Serial Number is located at the side of the router you will find a Sticker and look for the Serail Number you can also see there the Wireless Network Key under the Bar Code. Another Procedure to find the information of the router is to access it. listed below are the steps on how to access the router.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your Wireless Connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya.
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
Need 2700HG-B Drivers!
Try the following:
To access the System Summary page of your Router:
1. Open a Web browser and access the modem gateways user interface by entering http://gateway.2wire.net.
2. Click the System tab to open the System Summary page.
3. Either select
  • Run System Setup Wizard (to install your modem) OR
  • View available upgrades and options (to upgrade the software on your computer to the latest version.
If you do not have a manual for this modem, then click the link below and download it to your computer.
http://support.2wire.com/index.php?page=download
I hope this helps. Please rate. Regards,
Feb 16, 2010 | 2wire 2700HG-B Router (2700HGB)
My computer was wireless until I changed modems becausethe old one stoppd working
If you are using Windows XP, you go to start --> control panel --> network connections --> right click on wireless network connections & go to properties --> go to wireless network tab --> delete / remove all the networks under preferred network box then click on view available wireless or configure then connect to your network by clicking on the name of your modem --> type in the wireless password.
May 01, 2009 | 2wire (1000-000057-000) Modem
2wire wireless router/modem
there is only one quick way to turn off your wireless internet access.
Turn off the modem or router if you are using it.
For your information, all home networks have their own access key, without which nobody can access it... it is normally printed at the bottom of the modem. 10 digit encryption key.
Was I helpful enough??
Nov 07, 2008 | 2wire (1000-000057-000) Modem
2Wire Wireless Modem 2700HG-G
access gateway.2wire.net
home network icon
wireless setting tab
channel dropdown box=11
save
P.S u should know ur PW to do this
Oct 14, 2008 | 2wire (1000-000057-000) Modem
Problems setting up 2 wire router
ok, if you can log into the router at all, you should be able to go to home network, and halfway down will be the wireless configuration.
assuming it's set to default wireless security, there should be a network key writtten on a sticker on the bottom of the router:  You'll need to enter that code in windows vista before it will allow you to connect wirelessly.
Mar 25, 2008 | 2wire 2700HG-B Router (2700HGB)
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
2wire (1000-000057-000) Modem Logo
1,370 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
