Question about Canon PowerShot A85 Digital Camera
Canon Powershot A 85
My computer had a virus and I had a tech work on it. Apparently he removed my program that recognizes my camera and now I can't download photos. Please HELP!
My Canon PowerShot A85 Cameera will no long download pics onto to my computer. I've tried all three usb cords I have and is still will not work. It will read the card however. Help!
Thanks!
Melissa
Posted on Apr 22, 2008
  • Canon Master
  • 4,738 Answers
Go to the following page, select drivers and downloads tab. When the download page comes up, select your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=10462#DownloadDetailAct
Posted on Apr 06, 2008
SOURCE:
Computer not recognizing my canon powershot elph 110HS
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jun 01, 2014 | Canon Cameras
Unable to connect my Canon PowerShot A570 IS to my Thoshiba Satellite.Laptop doesn't detect the camera. It was working fine before my laptop got a virus infection. I reinstalled the program using the...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 15, 2011 | Canon PowerShot A570 IS Digital Camera
My zoombrowser program will not recognize when my camera is attached to the computer with the supplied cord. The computer recognizes that a camera is found, but will not let the program recognize it. ...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Aug 29, 2010 | Canon PowerShot A95 Digital Camera
PowerShot A85 Digital Camera: when I connect my camera (canon powershot a85) to ...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
May 16, 2010 | Canon PowerShot A85 Digital Camera
Canon PowerShot SD1100 IS not being recognized by my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
My computer is not recognizing my canon powershot sd1100is. this used to work so i do not know what happened. my computer will not download any pics off the camera. when i tried the connect to camera is...
What is the make and model no. of your camera, Was it come with any kind of software, if yes, Than uninstall the software and drivers for camera from the add or remove program and than reinstall it and replug your camera.
Jul 26, 2009 | Canon PowerShot SD1100 IS Digital Camera
Computer won't recognize the Canon powershot A570IS
Norton antivirus or antispam maybe thinking your driver is a virus so it is disabling it and prevent it from working correctly. In order to be sure, disable your norton 360. and reinstall the drivers for your canon. If it worked correctly, the problem is 100% from norton 360.
In this case you have to call canon and norton tech support to help you.
Before you call tech support, try change the security level to a lower setting and try again
Good Luck!!!!!!!!!!!!!!!!!!
Jun 15, 2009 | Canon PowerShot A75 Digital Camera
Canon powershot A460 camera not recognized by
Mar 03, 2009 | Canon PowerShot A460 Digital Camera
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot A85 Digital Camera Logo
64 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
