Question about Amana Kitchen Ranges
Amana First Edition Range Electrical problem
Amana ARR6300 or ARR6200 or ART6110 First Edition range. Problem: seemingly no power when plugged in but if you turn on a burner or the oven, it then lights the clock/timer. The burner will not heat up. As soon as you turn the burner off, the clock goes dark. The range was recently moved and a longer 6 ga wire was put in place to the junction box - all like for like. Any ideas?
6ya staff
SOURCE:
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: repair GE electric range
Door motor safety circuit you may have a faulty Electronic Range Control (ERC).. let us know what you find out.. krazytech
Posted on Sep 08, 2007
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
Anonymous
SOURCE: Oven does not heat
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
Posted on Dec 16, 2007
Anonymous
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Posted on Mar 11, 2008
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
My amana stove glass top is showing f9eo on board what do i do?
  1. You can power off your range by turning off the circuit breaker(s) or fuse(s) for 1 minute. Then power up your range by turning on the circuit breaker(s) or fuse(s) on.
  2. Monitor your range for at least 1 more minute to make sure the error code does not return.
Taken straight from the Amana website. Issue My range console has an error message Amana Owner Center
Oct 07, 2016 | Amana Kitchen Ranges
I have an Amana Self-Cleaning Range ARG7600. It is plugged into an outlet that is working but no lights come on. Does this model have an internal fuse that might be blown?
No fuses. All power is routed through the electronic control on the front of the range. The electronic control (ERC) will need replacing.
Jun 20, 2011 | Amana ARGS7650SS Gas Kitchen Range
Just installed Fridg. Gallery convection range
The PF code stands for "Power Failure". This code will appear whenever the power is disrupted to the range. Pressing the cancel button on the touch panel should clear this code. Now it sounds like there is either an electrical short on the range or a problem with your GFCI electrical outlet/breaker. There is an internal fuse that might have burned out inside the range to prevent further electrical damage or the ERC/touch panel may have shorted out. The problem is if you start tinkering with the range and it is brand new then you might void the factory warranty by trying to repair it yourself. I would leave it unplugged and call the manufacturer or the place that you purchased it from and describe your problem. There might be a recall on that model range or a problem that they are aware of. You also might want to try plugging a couple other appliances into the SAME electrical outlet plug that you used for the range and see if the breaker/GFCI trips. If it does then the problem might be with the electrical plug or circuit. A bad plug or circuit can cause damage to an appliance(like the range) so be careful with any other appliances you use to test the outlet because they could be damaged also if the circuit or plug is bad.
Apr 17, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
THe control panel doesn't display.
TURN OFF THE POWER TO THE RANGE THEN LOCATE THE SCREWS AROUND THE DISPLAY PANEL REMOVE ALL SCREWS AND OPEN UP THE PANEL CHECK WIRES FOR ANY WARE OR TARE ALSO CHECK THE ELECTRICAL CONNECTIONS ARE GOOD .
Nov 20, 2009 | Amana ACF4265 Electric Kitchen Range
Range top ignitor stopped working. electronic panel and oven work normally. Any idea what the problem is?
Hi, your spark module,for ignitor could be damage, sometimes they burnt out, or could be broken wires, or corrosion at electrical connection, (terminal) , normally it's spark module, that's faulty or burnt out. let mechanic check. or remove range plug from receptacle, and lift top of range, check all electrical wiring, check all connection for rust (corrosion) clean and retry range, if it didn't work, call mechanic to check spark module. good luck.
Aug 12, 2009 | Amana ACS3350AS Gas Kitchen Range
Our Amana AGDS902 Gas Kitchen Range is beeping and flashing an F7 error code. We have found solutions for other Amana ranges online, but none of them seem to be for our exact range type. We can stop the...
AMANA – Range/Stove/Oven Fault Codes
Glass link Electronic Range Control (ERC)
F7=Shorted touch panel Verify glass to adapter board connection good, if so, replace glass panel.
Dec 02, 2017 | Amana AGDS902 Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
Gas Range Oven use without electrical power
It will be necessary to change the top burner orifices when converting to propane. You should be able to light the top burners with a match or lighter, however, the oven will need proper operating voltage.
May 22, 2008 | Amana Ovens
Kitchen Ranges Logo
280 people viewed this question
Top Amana Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
