Question about Stoves Premier 720GRa Gas Double Oven
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
My dual fuel oven does not work - i operate it as i usually would but i find now that the fans rotate but there is no ignition and no flame to be seen as usual. The grill does not work either, yet the oven still blows air and operates it usually would but with no ignition and no gas? This is an intermittent problem as sometimes it works and sometimes it doesnt.
Please help!
Many thanks
Parma
  • 3 more comments
  • Anonymous Sep 10, 2008
    Similar issue
  • sturmey Oct 02, 2008
    yES ALL THE SAME. Intermittently (1 evey couple of weeks) neight top nor bottom oven will light. Fan goes round but no spark or flame. Wait 30 mins come back and it will work!
  • darren697 Dec 23, 2008
    Yes, I have the same problem also, it appears to be indicating there is a problem with the colour lights, I can also only turn on the top or bottom and not both at the same time, i.e. the fans spin on either the top or bottom but not both. Also of note is the lights on the dials are red on the left hand knob and flashing on the right. This according to the manual indicates something, however its not specific on what its indicating......
  • rienebell Jan 17, 2009
    Sounds exactly like my oven - any ideas yet? We don't have the manual anymore!
  • abuasil Mar 10, 2009
    hi their
    I have a q900 grf but I have no idea how it works, it has been sitting in my kitchen for more than four months and not working,if any one could give some hints, I would be gratefull.
    thanks
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Posted on Apr 15, 2009
No heat from fan oven
If the fan is working o/k, and the oven is not gas, then it will be the electric oven element that needs to be replaced.
They are usually located behind a removeable cover at the rear of the oven compartment.
Hope this helps.
Please leave feedback for my solution.
Thanks.
Dec 21, 2009 | Stoves Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
Cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Nov 27, 2008 | Stoves 720EF Electric Double Oven
Schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Stoves Premier 720GRa Gas Double Oven Logo
1,053 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
