Question about Kitchen Ranges
Maytag gas range
We bought a maytag sealed burner gas range-used. It is a power boost.
seemed to work fine, then in the middle of the night the timer went off, would shut it off, and a few minutes later it would sound again, with the message -F1- flashing. It didn't matter what I tried it continued, so I ended up unplugging it, any ideas
  • Anonymous May 26, 2009
    Our 15 year old Maytag power boost gas oven which works great has started beeping and flashes a F1 message even though we are not using it. When we hit cancel it stops but starts again a few hours later.
SOURCE:
catriver
  • 878 Answers
SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Posted on Jun 05, 2007
SOURCE: Maytag MER5770AAW smoothtop range
Seems Maytags have never fixed this problem. I have a 1993 and have had to replace the membrane (touchpad) every 4 yrs. If you can do it yourself, actually easy, you will save $$ for repairman, and can order part from Repair Clinic.com.
Only trick is carefully opening up the stove top, having someone hold it up for you while you disconnect the membrane...
Posted on Nov 13, 2007
vest6
  • 196 Answers
SOURCE: F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Posted on Dec 30, 2007
jyackle5
  • 8197 Answers
SOURCE: F1 message on Maytag range
This is what the code means.
F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Good Luck and Please Rate
Posted on Jan 08, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help. I was looking for a thermocouple but that must be old school. I couldn't figure out what told gas to flow."
Nov 20, 2009 | Maytag PGR4410 Performa Gas Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
Gas Oven Won't Light
make sure the wire is connected to the ignition(where it sparks)if it is gently clean the sparking surface with a piece of fine sandpaper.Hope this helps,if it still does'nt work you may need to replace this part but it should'nt be expensive and you can do it yourself(usually one screw) ps sorry for the late reply.
Mar 07, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Oct 16, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Auto light wont fo off
good day,
hope this link below will solve your problem.
ovens
Aug 15, 2008 | Rangemaster 110 (Gas) Kitchen Range
Igniter "clicking" on its own...
new spark module. Most stoves use a common part.
Jul 25, 2008 | Tappan 24 in. Freestanding Gas Range...
My maytag gas range has sealed burners. They need to be adjusted because they dont ignite properly and they blow out when you turn it on high
Peace,
ngafm here at your service,
How old is the range ?
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that burner so
it will come out with force.
If you have sealed burners and the cap and burner where the gas comes out, is removable by hand without tools!
You may want to check the gas holes in the removable burner is clear and or clean them out if they are clogged.
How old is the range?
I hope that these measures will help you remedy the problem simply and easily!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Jun 08, 2008 | Maytag MGR5751AD Gas Kitchen Range
Range mgr 5745 sealed burner
Yes the burner does twist off. You must turn it counter clockwise about 1/4 of a turn. These can be stuburn at times so what you might want to do is strike it sharply down with the heal of your hand first then give it a twist. this seems to help.
Nov 08, 2007 | Maytag MGR5751AD Gas Kitchen Range
Sealed Burner
Ralph, you need to look at the electrodes at the burners. They might be cracked or dirty. It's very hard to tell sometimes when they are cracked. The burner cap itself has to have a good ground and the wires going to the electrode should be on tight. You can eliminate the spark module by switching the right and left side burner wires at the module. Once you do that, if the right side works ok, but now the left doesn't, you can be pretty sure it's the module...Catriver..post back.
Mar 03, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
Kitchen Ranges Logo
91 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
