Question about Candy Refrigerators
Fridge freezing on a candy cpc 240 ffk - Candy Refrigerators
  • Anonymous Jun 22, 2008
    My lights have stopped working and everything in the fridge freeze.
  • flashg1 Oct 07, 2008
    power light goes on and off for a period and a sort of fan noise is heard. When the door is opened during this time (which could last for maybe an hour and a half or less) the internal light is seen to go on and off in tandam with the green power light. The freezer does'nt seem to thaw out. When it returns to normal, it could last maybe for another 24 hours before the same fault occurs again. It's an intermittent problem and very annoying!
3 Suggested Answers
SOURCE:
SOURCE: Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Posted on Nov 14, 2008
woodchuck789
  • 4070 Answers
SOURCE: Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Dec 03, 2009
Why is my fridge freezing up in my candy fridge freezer
Hello there,
The reason your fridge is freezing up is simply because there is a problem with the defrost unit of the refrigerator. The defrost thermostat simply could have gone bad and therefore is not getting the defrost heater to start work.
Have the defrost thermostat tested and replaced once found faulty.
Hope this was of help to you. All the best Elect_Comp
Sep 26, 2011 | Candy CPCA240FFK Bottom Freezer...
Dec 03, 2009 | Refrigerators
The fridge of my candy fridge freezer is far to cold and almost freezing goods,the fridge is set on the recommended number
check to see if the coils underneath the fridge are clean. It seems more like an airflow problem. The chances of the fridge being under or over charged with refrigerant is not likely ..
Nov 15, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge is freezing stuff
try to call a technician the defrost system of Ur fridge might be damaged or u have a leak of gas on ur system.. tell him to check the thermostat.. also
Mar 09, 2009 | Candy CPCA270FFK Bottom Freezer...
Freezing frosting fridge
i had the same problem recently with all my fridge food freezing up, this all seemed to start when i discovered the interior bulb blown i replaced it still nothing also noticed warning lights on front out,i could hear the motor going so i knew it was on i removed back cover and found the heater covered in ice it turned out it was the failure of the control board causing these problems had it replaced and working fine now hope this is of help dmb23
Jan 10, 2009 | Candy CPCA240FFK Bottom Freezer...
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPC 290 FF
Hello
Well the sheet of ice was caused by the thermostat failing and causing the fridge to continously run therefore causing the over freezing..
Like a car engine if you leave it running for weeks on end without stopping it probably will burn out...
Or like a horse is you have it working day in day out with out rest it will die..
you compressor on your fridge is no more... it ran and ran and now its all worn out .....
The clicking noise at the back of the fridge is the compressor trying to swtich on but it can't
only a professional can legally change over the compressor
as it is a techincal process recharging the fridge with gas
if you need any other help let us know...
you need a new fridge by the way
Jan 10, 2008 | Candy CPCA270FFK Bottom Freezer...
Refrigerators Logo
42 people viewed this question
Top Candy Refrigerators Experts
John Tripp
John Tripp
gbob59
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
