Question about Microsoft SQL Server 2000 Standard Edition for PC
Sql server how to install sql server on window XP?
  • 8,596 Answers
It should install automatically when you insert the CD - double clikc cd-rom drive if it does not begin to load.
This might be a useful article - there was a bug - you may need to upgrade to SP2. http://www.microsoft.com/sql/prodinfo/previousversions/system-requirements.mspx
Note: If you are running a 64-bit version of a Microsoft Windows Server™ operating system, you need to use SQL Server 2000 Enterprise Edition (64-bit). Visit the SQL Server 2000 (64-bit) System Requirements page for additional information.
Posted on Jul 03, 2008
Tip
SQL 2008 SA Password Reset
How to reset sa password in SQL Server 2008 when forgot the sa password?
Many time, This problem comes, they have setup SQL 2008 or SQL 2008 R2 for development or QA environment, but they don't know the login sa password by which they can connect to server. In SQL Server 2005, SQL used to fixed group sysadmin with the server role BUILTINAdministrators, that is to say, all local NT administrator automatically add a SQL Server system administrator. But since 2008 Windows BUILTINAdministrators group is not included by default in the sysadmin server role in SQL Server.
So, follow the steps mentioned to reset SQL 2008 password for SA account if no BUILTINAdministrators.
Step 1. Download and install MS SQL Server Password Unlocker.
Step 2. Run MS SQL Server Password Unlocker, click Open, import the master.mdf file. All the user names of your SQL Server will be displayed.
Step 3. Select an SQL account, such as 'SA', click Change Password button.
Step 4. Type a new password, and then click OK.
The new password has been set for your SA account, now you can login
SQL Server with the new password.
Currently SQL Server 2008 still supports two types validation and authentication for access link to resources database, Windows authentication mode and SQL Server and Windows authentication mode which also known as mixed mode. Both of these authentication methods provide access to SQL Server 2008 and its resources.
The Mixed Mode - SQL Server and Windows Authentication Mode
SQL Server and Windows Authentication Mode uses either Active Directory user accounts or SQL Server accounts when validating access to SQL Server. SQL Server 2005 introduces a new way, the policy of the password and account lockout the policy session of SQL Server by using SQL Server implement authentication. SQL Server 2008 also to do so. The policy of SQL Server that can be used include password complexity, password expiration and account lockout. This feature is not available in SQL Server 2000 and becomes a major security risk for most organizations and database administrators. In essence, this weakness has contributed to the Windows authentication set as best practice for the management of authentication in the past. Today, SQL Server and Windows authentication mode may be able to successfully compete with the Windows Authentication Mode.
on Oct 26, 2010 | Computers & Internet
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Forgot SQL Server SA password. How to reset user password to login SQL Server?
When SA password for SQL Server logon forgot, please take SQL Password Genius to install it on computer.
Step 1: Run SQL Password Genius full version and browse Master.mdf file to import into it.
Step 2: Select SA user and click "Reset" button.
After master database file imported into SQL Password Genius, you would see all user in list. SA password is unknown. Select SA account and click "Reset" button.
A new window would pop up, type new password for SA account in it. And click "OK". Instantly, SA password is changed successfully. SA password lists in software screen.
Step 3: Close SQL Password Genius and restart SQL Server Services.
SQL Server services influence SQL password reset on computer. So we stop it before using SQL Password Genius. Now, when you finish SQL SA password reset, restart SQL Server Services to run SQL Server with SA account.
How to Reset SA and Other User Passwords for SQL Server
Jun 27, 2014 | Microsoft SQL Server 2005 Enterprise...
How to recover SQL server mdf files?
RecoveryFix for SQL database recovery software is recover and repair MDF files components from corrupted SQL server database. This software compatible with Windows 7, Server 2008, Vista, Server 2003, XP and 2000. More details see this site: http://www.en.repairsqlserver.net/ or download this tool from http://www.en.repairsqlserver.net/free-trial.html
May 06, 2014 | Microsoft Database Software A5K-02817 SQL...
I can't install the service pack 3 of SQL server
Are you installing SP3 for SQL 2005 Standard or Express editions?
According to Microsoft, the standard edition will not work on XP Home.
See:
http://technet.microsoft.com/en-us/library/ms143506(SQL.90).aspx
Aug 01, 2010 | Microsoft Windows XP Home Edition
How to instal sql software i hav a software but dnt no how to instal
Insert the CD in the CD drive and when you get the run box select to run the program. It will install itself, all you have to do is make a few selections by answering questions during the install process. The easiest way is just to accept all the default settings.
Jul 20, 2010 | Microsoft Windows XP Professional
Unable to add local server with SQL-Server Management Studio 2005
ok, you installed the management studio but did you install SQL server?
That is not part of the management product.
Jan 03, 2009 | Microsoft Windows XP Professional With...
Microsoft SQL Server 2000 Standard Edition for PC Logo
201 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
