Question about Dishwashers
The Rinsing aid door keeps opening in my Bosch dishwaser
The rinsing aid door in my Bosch SHU43C05UC keeps opening and I lose all the rinsing agent.
I close the door, load and start the cycle. When it's all done I go to take out the dishes , the little lid is open always.
Any solution? Does the lid needs replacing?
Thank you
H
  • paddy55 Apr 12, 2009
    Hi:
    I have the same problem with mine, a SHE56C06UC.   I was wondering if it might have to do with the  the top rack as it has only started happening since we moved it the rack to higher position.  Seems to be an intermitent problem.   The rinse aid door appears to be OK, I have tried to pull it open, without touching the latch, and have been unable to do so.  Also the rinse aid indicator light went out about the same time this all started.   Hope we can find a solution.
    Thanks
    Pat
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Posted on Apr 22, 2009
Oversudsing
Rinse aid setting too high or has been spilled. Turn the rinse aid dial to a lower setting or wipe the spill.
Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic
dishwasher.
Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent.
Feb 19, 2011 | Dishwashers
Hi, I have an BOSH dishwasher SGV4313gb/17. It is about 8yrs old and has worked fine until last week when it did not complete its cycle. Have reset and it seems to complete cycle but I don't think it...
Are you using a rinse aid? if so and teh dishes are still not drying properly, try adjusting the setting for the rinse aid dispenser. Open the door of the dishwasher, open the flap where you pour in the rinse aid and look for the cirlce with the arrow and nunbers on it. If it is set low (1 or 2) try turning the arrow to a higher number. If that adjustment doesn't work, increase again and again until the dishes are dry.
Jan 05, 2011 | Bosch Dishwashers
Bosch Dishwasher will not dry dishes, washing is fine. Model SHU43C05UC / 17. About 4 years old. Cannot find the manual. Any help is appreciated.
Bosch dishwashers do not have built in heated dryers. Be sure your water is hot enough and the rinse aid dispenser is not empty. The Bosch should heat your water to a minimum temp and if it is not, this could be your problem.
Ken
Oct 25, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
The dishes are pretty wet as is the inside of the dishwasher after a regular run. will a rinse agent fix this?
Rinse aid will help.The Bosch dishwasher uses the captured heat from the water to dry the dishes.turn on your dishwasher ,wait 20 mins and open door .Does steam come out?if yes rinse aid should do trick,if not water is not heating and you probably have a bad e.control (common problem)est repair cost in Boston area $229.. Hope this helps ,please rate my response :)
Dec 08, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Carries on washing and rinsing until door is opened
have had similar problem with Bosch DW. read this link invcluding comments and replies at the end.
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Nov 01, 2009 | Bosch 18 in. SRV43M03 Built-in Dishwasher
Not rinsing soap still on dishes
try washing the dish washer out with a good drain unblocker the system gets cloated up with grease, then use a dishwasher salt with the washes this will help to remove the suds ets, most dishwashes have a compartment to put either liquid or solid dishwash aid in try a different aid, also if you use tablet form i desolve it first in hot water in a small container
then place that into the dishwaser on the lower shelf, that helps
Aug 16, 2009 | Dishwashers
Soap in JetDry dispenser.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Hope this helps and best regards!
Aug 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
I don't know where to put the Rinse Aid
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
May 22, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Dishwashers Logo
323 people viewed this question
Top Dishwashers Experts
