Question about Acer Aspire 3680 Laptop
Broken Power Pin
My aspire 3680 is just over a year and the power jack on the board is broken.
Am I correct to say that this is a common problem? My laptop is out of manufacturer's warranty by few days and idea where I can purchase this part? Acer's web site is not user friendly because their search engne doesn't take me to their parts website
  • dark_mast672 Jan 25, 2009
    the pin fell out of my power jack
  • 589 Answers
Your model has a power jack that is soldered to the mainboard.
Yes, this is a common problem with a lot of notebooks. It usually happens when someone walks by and trips on the power wire and pulls the notebook off the desk / table and onto the floor.
Unless you're comfortable with taking it apart, and good with a soldering iron, you should take it to a repair shop.
If you ARE comfortable with doing so, the power jack can be purchased from several suppliers on Ebay, for about $12 including shipping. Just do a search for "aspire 3680 jack" and you will see them.
PS: Most shops charge $100-$150 to replace the jack.
Posted on Apr 06, 2008
I have an ACER SPIRE 3680 2682, is bad, is not running, does not power on. Is not the ac-dc adapter, that one is good. The problem is on the mother board, dc source?, video chip?, other?. Please answer at...
If no lights, no sound then the problem with the Motherboard Power section Problem, like the DC pin is broken or any shorts etc etc. If Power light is On no Display then the problem with the Display video chip, have to reball the Chip or Replace the chip, service center's only fix this type of issue. best of luck
Feb 21, 2011 | Acer Aspire 3680 Laptop
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 08, 2010 | Acer Aspire 3680 Laptop
Aspire 3680 Won't charge
Have you tested the A/C to be charging correctly ? Have you confirmed that at the back of your laptop where you plug the power in that the pin is not bend and not missing or broken or pushed in ?
If your new battery and the old battery give you exactly the same issue, then most likely your A/C power adapter or cable OR the physical port on your laptop is broken and needs to be replaced.
May 14, 2010 | Acer Aspire 3680 Laptop
BROKEN POST FOR POWER ADAPTOR GOING TO BOARD.IS THE CIRCUIT BOARD REPLACEABLE OR CAN I REPLACE THE POWER BLOCK PART? ACER 3680 - 2007 MODEL
If the pin on the power socket itself has broken, then you are in luck because Acer uses a satellite board for its power to the motherboard, so no soldering is needed. I'm including a link below for a replacement board to get you back up and running.....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280408569438&ru=http%3A%2F%2Fshop.ebay.com%3A80%2F%3F_from%3DR40%26_trksid%3Dp4712.m38.l1313%26_nkw%3D280408569438%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Oct 14, 2009 | Acer Aspire 3680 Laptop
Power Board Problem and Power Button Hinges Top Cover broken
It would be cheaper to have the power board repaired but the replacement is around $55 from ebay. I'd get a new moulding for it if its available or even if you got somthing plastic welded up.
http://cgi.ebay.com/Acer-Aspire-3050-3680-5050-Power-Board-w-dc-jack-usb_W0QQitemZ120415274982QQihZ002QQcategoryZ158887QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps
May 06, 2009 | Acer Aspire 3680 Laptop
Acer 3680 ac pin broken
That's really not advisable. At our shop we do socket repairs, I suggest finding someone local who specialises in laptops and asking them to replace it. You can get the sockets on e-bay, etc, if you wish to try it at home, though I don't advise it.
Don't forget to take static safety precautions!
Aug 19, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Pin stuck in charging jack!
It is broken, you are going to have the DC jack replaced.
Dec 27, 2007 | Acer Aspire 3680 Laptop
Pin stuck in power adaptor
Acer aspire 360-2682 notebook
better no to disassemle laptops by your own refer to a qualifying service proffesional
Dec 03, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
