Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Idle I have a BEFSR41 and i seem to lose internet connection everytime my computer goes idle for about 10minutes. i have tried solutions suggested by linksys but the problem is still there. i need help! thanks in advance guys
  • relentless99 Apr 07, 2008
    that was the first suggestion of linksys. i already did that then reset the router. i also lowered the MTU (whats MTU btw?) and tried changing cables to cat5. the problem is still there. hope you could give more suggestions. thanks!
You only have that option if you set it with PPPOE. i lose intenet connection if i apply that setting
Posted on Apr 13, 2008
All u have to do is go to 192.168.1.1 and set ur idel time up
Posted on Apr 11, 2008
Befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Posted on Apr 06, 2008
SOURCE:
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
I set up my lynksys befsr41 ver4.1 using the set up disk. I hit enter at the password window and it goes to analyzing my computer. Then the password window shows up again etc. etc. etc. At the lower left I...
Are you trying to install the router.
You can do it manually without the CD.
First reset the router for 30 seconds. unplug the power to the router. wait for 5 seconds. Plug it back in.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Losing connection constantly, when I hok up computer directly to the modem I have no problems, but with the router my internet does not work. The lights on the router are flashing and indicate that it is...
have you done a chat with Linksys? What do you use to manage your network?
May I suggest you get Network Magic, a free download and eval period.
Using Network Magic, you may find you have settings on the router that prevent your getting past your 'fire wall'.
Oct 12, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
BEFSR41
Log into the router and see if it is set to grab DHCP from the ISP, it may need to have a static IP set.
Jun 19, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
MY INTERNET GOES DOWN EVERY TIME THE FAX MX310 RINGS
There are some good suggestions here. Check out the solution and follow the steps. The reason dsl seems to be being dropped is the noise in teh line, and as far as I can tell this is a very common problem. Try these suggestions out but you may want to just purchase a better fax machine.
http://www.fixya.com/support/t374109-canon_mx310_fax_noise
Apr 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Blinky...
the solution buy another router you you can use other cp
Apr 14, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
USING LINKYS ROUTER/INTERNET NOT FOUND
Can you be a little more specific. What do you mean by "INTERNET PLUG IN"? Are you referring to the cable connecting your laptop to the router? The router to the modem? Or the modem to the internet (cable or DSL)?
What operating system?
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
100 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
