Question about Car Audio & Video
I have recently bought a new car and the wires from the old stereo have been cut! Im having trouble putting my new stereo in. Would you be able to help?
  • 185 Answers
Im sorry but unfortley i cant help with that issue maybe the libray let me no if that works
Posted on Apr 06, 2008
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i...
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Jun 06, 2011 | Car Audio & Video
Im in great need for the color coded wires for the factory stereo, I just bought the car and the person who had it before me, ripped out the stereo and cut off the wiring harness before the bank...
ok there should be 8 speaker wires, red wire +, a yellow wire acc(i think its called) and a black wire -, the after market stereo will come with a harness and it will be labled to make it easy, with car speakers it dosent watter what why you put the wires on the same speaker as they are both positives, if there are any left over on your stock loom I would not worry thats all you need. Just ask me if you need any more help
Aug 15, 2010 | 1998 Cadillac Catera
Im putting n a stereo but i dont no the color code
The stereo side of the wires should be labeled. Check out the12volt.com for a wiring schematic for the truck side. I advise against cutting and splicing wires for a stereo installation though. They make inexpensive harness adapters that will allow you to splice into the stereo harness without cutting into the factory wiring.
May 23, 2010 | 1998 Dodge Ram 1500 4WD
CAR STEREO SOUND CUTS IN AND OUT
yes those are some of the facture to check but first i want you to disconnect all spk and rca and turn on amp and then start connting using one rca and one spk wir connect one by one and see wht happen
Apr 01, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Car stereo switch out
Ok, first off, NEVER CUT WIRES!!!! what you need to do is go to your local audio store ie. best buy etc. buy a wire harness. It makes everything so simple, just match colors. If your wires are already cut, then you need a haynes manual about $15.
Feb 10, 2009 | Alpine CDA-D855
Ive bought a peugeot306 recently and the person who had the car before has took there car stereo out and cut the wire, so now im having trouble putting my stereo in. thanks
  • First thing to do is isolate all the cables from each other and put insulating tape over the bare cables.
  • Now using a multimeter set on 12 volts or above test each cable in turn with the ignition on.
  • You will find one live cable that is only live when you have your ignition in the number one position.
  • This is the live feed to your radio, fit a small amp-age fuse (5 or 7.5 amp) depending on the rating for your new radio.
  • You will have speaker wires, these you can identify by tracing them from each speaker.
  • By now you will have identified your live cable and your speaker cables.
  • You may have a secondary live for a electric aerial and an earth cable. You must earth your radio even if you have to make an earth on the inner bodywork.
  • If you do not need the secondary live then make if safe.
  • If you need the secondary live fit an appropriate fuse.
  • Earth the new radio.
I use this system on used cars before fitting radios/cd players. It works but be careful.
Sep 18, 2008 | Peugeot Liberte Cars & Trucks
No power to radio
I just finished installing a new system in my 94 100s.To make it easy for me I bought a direct-fit connection kit from Crutchfield online. The connection fits into the one from your car and then you just wire it into your new stereo! I hope that helps.
Jun 23, 2008 | 1994 Audi 100
Car sterio
A picture of what you have would be helpful.
Apr 23, 2008 | Car Audio & Video
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
