Question about Sewing Machines
New Home Timing specs?
Saw in one of your posts that you seem to have some New Home service manuals. Would you be able to tell me what the timing tolerances are? I've found this pic online:
http://www.sewusa.com/Sewing_Machine_Repair/Repair_Pictures/timing3.gif
From your post it seems like 23b is probably the same (.05mm), I'm wondering if 23a is the same too (1.2mm) as mine is about 5mm or so.
Thanks.
  • Sewing Machines Master
  • 1,388 Answers
Not sure who this was addressed to, just came across it today.
What model machine do you have ?
Timing is fairly straightforward.......if a top loader, then:
Remove the bobbin case, & set to widest zigzag.
When the needle rises to where the tip point is level with the top of the white plastic inner of the hook race, the hook point must align with the right side of the needle (as it rises).......the zigzag will be in the left position of it's swing (so the hook is travelling it's greatest distance)
The .05mm is the distance apart (Hook & Needle) so it seems you are OK on that score.
Depending on which model, there are several options for the hook timing....usually 2 hex nuts on the bottom shaft, to liberate the bottom shaft from the connection with the drive belt/crank so you may then adjust the hook position to the above mentioned position, re-tighten...... et voila !
Here is the same thing for a Jem Gold direct from the manual:
If this is sufficient, great, if not, let me know the model it will usually start with "V" on the compliance plate........a photo could also be helpful as we only have Janome in Australia, so shall need to translate the model across (same company makes them both, and Kenmore !)
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 14, 2008
  • Hassy
    Hassy May 09, 2008
    Has there been any progress on this solution ??
6ya staff
SOURCE:
Needle hits bobbin casing.
Don't know if you have a manual or not. You can read the manual from the link below. I would look for the bobbin area in the manual. There should be a section showing the bobbin area for cleaning and oiling. It may as simple as removing and reassembling the bobbin case.
It could be the timing and would require a service repair technician.
https://www.manualslib.com/manual/545699/Riccar-9600.html
Jul 11, 2017 | Riccar Sewing Machines
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
New home sewing machine is not picking the bobbing thread SL2022.did the adjustment,cleaned up,oil too,still skips when I sewing ,but now is not sewing at all
Install a different brand new needle.
If that doesn't work, the timing is probably off. Search for sewing machine timing or take it for service.
Feb 09, 2017 | New Home Sewing Machines
John shearer parts
Like previous post this lady has plenty of service and operator manuals
www.sewing-machine-manuals.com
Mar 28, 2014 | Brother Sewing Machines
Need a manual for Consew 206RB. Any takers?
Servicing the Timing is NOT a home fix
Feb 26, 2014 | Consew 206RB
Overload reset button on porter cable 10 in table saw
Why this is in sewing machines I will never know.
But this is an example of pushing a saw beyond it's limits. At best you should have cut one post, shut the machine off and let it cool... then go for the next. (Better yet get a friend with a saw mill saw the thing down for you)
I believe you have burned out your motor. Off the store you go....for a new one.
Oct 25, 2013 | Sewing Machines
Noisy bobbin bounces in case
If you just had serviced a month ago I would take back and tell them to fix the problem you did not have before they serviced it, or try calling maybe then can advise over the phone.
Jul 17, 2017 | Sewing Machines
Using a White model 616 with a twin needle?
singer has a free manual in pdf form for the machine, which can tell you if the machine is capable of using the twin needles
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w616 ) & click search
May 21, 2012 | White Sewing 1866 Mechanical Sewing...
Sewing Machines Logo
192 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
