Question about Refrigerators
GE Profile Cold Control
My GE Profile will not get to the recommended 37 degrees for the fridge part. It stays at the most 30 degrees. The freezer temp is fine.
    Genius:
  • 3,422 Answers
HI,
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. i recommend you contact a qualified appliance repair technician if you cannot replace it by yourself.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 06, 2008
  • Refrigerators Master
  • 19,396 Answers
Your thermistor switch may be defective, and stop the cooling before time
  • Ginko
    Ginko Apr 06, 2008
    If your fridge is too cold, you may also have an ice condensation problem. Check that the evaporator fan is working. and leave the fridge defrosting overnight, unplugged and with doors opened.
    If the above does not work, then again you need to change the thermic switch , as it is probably defective.
SOURCE:
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My GE profile side by side is not freezing on the
TAKE THE BACK PANEL OFF INSIDE THE FREEZER AND REMOVE ALL OF THE FROST WITH A HAIR DRYER. THE GLASS HEATEER AT THE BOTTOM OF THE ALUMINUM EVAPORATOR MAY NEED REPLACED. DEFROSTING THIS AREA WILL ALLLOW IT TO WORK FOR ANOTHER 10-14 DAYS.
Apr 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
