Question about Acer Aspire 1640Z Notebook
Acer Aspire 1640 laptop mouse pad does not work
Dear Sir:
My Acer recently locked up while using it and I had to do a poweroff to shut it down and then started it again. Whenit started I found that my mouse pad on the computer would not move thecursor. I shut offf the computer in the noraml waythrough Start several times, but the mouse pad still does not run thecursor.
I do have use of the computer since I have an external mouse I use atmy desk and this works fine as it is connected through the USB port.
I would appreciate any help you may have in reconnecting my mouse pad with the cursor.
Regards,
Charlie
  • 3 more comments
  • charlie6900 Apr 06, 2008
    The Fn/F7 key enabled and disabled the touch pad, however, when
    enabled the touch pad still did not work, so something else must be the
    problem.
    Thanks Hollyecho for the potential solution.
    Charlie
  • CAMROSEY Jun 15, 2008
    MOUSE PAD DOES NOT WORK...
  • Anonymous Jun 24, 2008
    I have the same problem with that thing my touchpad mouse does not work at all hope you help me with this.I have my acer aspire model 5520-5912
  • Tasha2687 Nov 22, 2008
    I recently had my laptop cleaned and, when I got it back the scrolling up and down on the touch mouse pad stopped work. I have pressed Fn/F7 that doesnt change anything. Anyone have ideas please help
  • amandaheeelp May 22, 2009
    My problem is similar only the mouse will move when I use the mouse pad, but when I try to click on anything it does not work. I have tried disabling and enabling the mouse pad, but it does not correct the problem. Please help.
    Sergeant:
  • 318 Answers
Hit the Fn (funtion key) HOLD it down WHILE pushing the F7 Key - this will turn your touchpad back on.
For the complete manual for your computer:
http://www.acerpanam.com/synapse/data/7117/documents/AS1640_Guide_EN.pdf
And these instructions were found on page 25.
Posted on Apr 06, 2008
My acer T4200 laptops moupasd does not work suddenlu,plz solve my problem in the simple way?
Posted on Sep 15, 2009
This solution worked for me! thank you soo much. i thought i was doomed
Posted on Aug 17, 2008
    New Friend:
Dosenot work mouse pad ,what may work mouse pad
Posted on Mar 19, 2011
SOURCE:
The built-in keyboard of My Acer-Aspire 4741Z Notebook, sudently stoped responding..built-in mouse (Touch-pad) is working..Pls advise me
Press poweroff button for some time, the laptop will go off. Then once again start the laptop by pressing the power button. This method is named as "Cold reboot".
If still issue, please post on this.
Thanks,
Amar
Sep 22, 2011 | Computers & Internet
DEAR SIR, I have a laptop of acer aspire 5500z series model no. fl50 i have problem that the internal mouse pad is mistake nd now not useble for me so pls ask me how that problem to be solve.
not 100% sure of your query but will have a go. If you have deleted the drivers for the mouse pad then you can get them here. If the mouse pad just doesn't work you can plug in a usb mouse and that will work.
Apr 15, 2011 | Acer Aspire 5500 5570-4421 Laptop
Hello my little brother was playin like he was on the piano and the touch pad locked up i dont know how to unlock the touch pad
Re-boot the computer. If you can't use the mouse to shut down, hold the power button down until the computer shuts off - then re-apply power.
Nov 28, 2010 | Acer Aspire One PC Notebook
The touch pad mouse on my Acer Aspire one doesn't work.
if you have an esternal mouse istalled try to go to the device manager and unistall all the mouses on the mouse section.. shut down computer, remove external mouse and turn it back on. it should work now
Oct 08, 2009 | Acer Aspire One PC Notebook
My mouse pad does not work nor does USB cable
Has the mouse lock been applied.
Press and hold the "FN" key and then press "F9" this should unlock the mouse and touch pad.
Failing that try updating the drivers for both using the device manager as I have found that recent updates have disabled my touch pad and I have rolled back the drivers to the previous ones.
Aug 15, 2009 | Acer Aspire One AOA110-1588 Notebook
ACER 5315-2326
Disconnect it and connect again.
Oct 27, 2008 | Acer Aspire 5315 Notebook
Notebook Keyboard will not work and neither does the touch pad for the mouse
well..maybe..could be the cables under the keyboard have loosened, or it would be a mother board issue then
Oct 09, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5520-5334
check to see if it was locked press fn and F7 to toggle between lock and unlock of mouse pad functions.
May 31, 2008 | Acer Aspire 5520-5908 Notebook
Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
Mar 15, 2008 | Acer Aspire 1642ZWLMi Notebook
Acer 1640
  • shutdown and power off your acer laptop
  • then remove the battery out of laptop
  • connect the power and switch on ur laptop
  • let it boot to operating system
  • check if its working now? ur keyboard and mouse should be working now
  • you can now connect the battery and keep working.
  • if u want to power off, put ur laptop in hibernate more, rather than shut-down. so u dont have to reboot next time without battery.
  • if u restart or start ur laptop after a shutdown, make sure to remove the battery first
    i hope this will help.
more details can be found on the cnet forum @ http://forums.cnet.com/5208-6620_102-0.html?forumID=44&threadID=294657
Jan 03, 2008 | Acer Aspire 1642WLMi Notebook
Acer Aspire 1640Z Notebook Logo
5,991 people viewed this question
Ekse
Alun Cox
