Question about Sharp AR-M160 Laser Printer
I get a letter 'd'
Hi
I have a Sharp AR-M160 and was working perfectly until 2 days ago.
Now it reads the letter 'd' on the panel which means 'download' and can't do much with the machine.
No photocopying, no scanning and no printing.
The entire place is blocked.
Help appreciated.
Thanks, Sam
[email protected]
    New Friend:
  • 9 Answers
The mcu bord is not working chack the mcu bord
Posted on Oct 30, 2009
SOURCE:
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
AR-M160 Black and White Copier: it flashes H then 2 will not copy...
H2 means termistor damaged enter code 14 .if not solved change termistor
May 17, 2010 | Sharp AR-M160 Black and White Copier
I WANT A PRINTER DRIVER FOR SHARP AR-M160
follow the link below:-
http://www.businessneedz.com/Sharp-AR-M160-AR-M205-Downloads.htm
plz rate the solution...
Nov 14, 2009 | Televison & Video
Where to get driver for Sharp AR-M160 for Windows 7
http://www.bioticaindia.com/ar-m160.html
Here is a link to a driver you can try. It is very possible that there is not a driver available that is compatible.
Thank you,
lee
Nov 10, 2009 | Sharp AR-M160 Laser Printer
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Ch error
Some of the covers of the machine might be open.
Regards,
Cäppärs
Jul 17, 2008 | Sharp AR-M160 Laser Printer
Scanner problem
Here is a list of drivers.. Since I do NOT know your OS, this page has MANY OS options...
Good Luck
May 30, 2008 | Sharp AR-M160 Laser Printer
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Laser Printer Logo
94 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
