Question about IBM ThinkPad R40 2722 Notebook
Boot problem when i startup my notebook, two statements appears error 0271 - check date and time setting error 0276 - the system has been tempered with - security system then suddenly 'key' icon appears. it's like a password or something.. i cant log onto windows. i can't even log onto bios. please help me.
  • Anonymous Mar 31, 2014
    my pc boots but a green screen appears after the acer log and it ends there. two icons appear the other for ease access and the the restart icon
I had exactly the same thing happen. I had a free laptop and wound up letting the main battery drain which drained the CMOS battery resulting in the time date issue you see. I am not sure about the tampering message but the key icon means there is a supervisor password set. I looked online for a month to find a better solution but the best I could come up with was from this site. I followed their advice to the letter and it worked.
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
You will need to know how to solder and not be afraid to take the laptop apart. There is no other way than this to deal with the supervisor password. You will have to flash the chip and read the binary dump. there is software you will need for both of those operations. Once you get the password, you can enter it at the lock screen and then get into the BIOS.
Best of luck. I did it and I ain't that darn smart.
Posted on Jun 30, 2009
Display problem & booting no bee
Posted on Jun 02, 2008
  • 159 Answers
There is a security chip located on board the you may have tampered with or not i have seen cases where just simply putting a jump drive in the usb causes this error the chip sold on ebay for $14.99 if you need help open up the lappy please dont hesitate post i will help.
Posted on Apr 07, 2008
How do you set the system date and time
To set the Date & Time, go into the BIOS setting - date 7 time.
When you set the Date & Time and you get this error again when you next boot up your computer, then most likely you have a flat BIOS battery.
Then replace this battery, it could be a coin size battery - 3 volt lithium battery type CR2032. and then go into the BIOS setting and set the Date & Time.
Oct 22, 2012 | Gateway Essential 500 PC Desktop
T30 keeps giving me an Error 0271
Error 0271 Date and time error-Neither the date nor the time is set in the computer. Run IBM BIOS Setup Utility to reset the time and date.
I suspect the CMOS battery needs to be replaced.
Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise! Thankyou for using FIXYA! Bestregards,
Junior
Sep 23, 2011 | IBM ThinkPad T30 2366 Notebook
Need password for entering windows. there is error 0271: check time and date setting. my friend said that the motherboard error, must be reset or change... what should i do???
I have the same problem with a desktop.
To bypass the error, You might need to set the correct date and time every time you power up your laptop. Date and clock setting can be set via CMOS configuration.
Jun 13, 2011 | IBM ThinkPad T23 2647 Notebook
Everytime I open my laptop. it always appear.. error 0271 check date and time settings.. then he need a password to continue?? can you suggest what other options I can do to continously open my laptop...
It indicate that battery cell which called CMOS has been finished his lift. replace the same with new one set date and time and you will be done INSHALLAH.
Sep 24, 2010 | Computers & Internet
Error 0271 check the date and time setting
The BIOS battery is flat and cannot keep the corrected date and time. Replace the BIOS battery anf then go into the BIOS configuration to set the time and date.
Mar 13, 2009 | IBM ThinkPad T20 2647 Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
My IBM thinkpad A21e is showing me an error message
You need to replace your BIOS battery. The battery is old and cannot maintain the BIOS configuration. That is why you are getting incorrect date and time and bad CRC error.
Replace the battery and then configure the BIOS settings.
Jan 27, 2009 | IBM ThinkPad A21e 2655 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Jul 17, 2008 | IBM ThinkPad T21 Notebook
Cmos password for ibm r40
You will have to remember it. IBM puts a security chip on the motherboard, the bios password is burned into this, and there is no way around it. There are a few places that will replace the chip, but they are very expensive. The only other way is to replace the motherboard. I've found that replacing the motherboard is cheaper than having the chip replaced, so, if possible, remember the password.
Jun 30, 2008 | IBM ThinkPad R40 2722 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad R40 2722 Notebook Logo
572 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
