Question about Edirol UM-2EX External Sound System
Not even lighting up!
I got one of these for Christmas and at first when I connected the MIDI cables of my keyboard to my macbook pro, it was a bit fidgety but eventually connected. Now when I try, the usb light goes on for a second and then dies. I tried re-connecting everything, restarting my computer and even changed the midi cable, but nothing works. Everytime the computer restarts is the only time it actually recognizes it's there. What could be going on? Is it broken?
  • dodeweert Oct 20, 2008
    i have  a i mac and when i start my computer the um-2ex blinks for a few seconds and then it stops!
I had the same problem -- the following worked for me:
Go into your Audio MIDI Setup application -- there should be an item in the window called "IAC Driver." Double-click it and check the box that says "device is online." If everything else is connected/set up, this should fix the issue.
Posted on Aug 01, 2009
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
How to solve midi connectivity issue with Yamaha keyboard?
You will need to send it in for repair is my assessment.
Mar 03, 2017 | Yamaha Audio Players & Recorders
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
How to connect a MIDI keyboard to computer
There are quite a few ways to do this.The simplest way is to just use the USB port on the keyboard and run that into the computer. If your keyboard has a USB, then you dont need the midi to connect to a computer. You would still use the midi however for other sound modules and items that do have a midi in port however. If you dont have a midi in then you need to get hardware that does as a computer will not have a midi in. There are basic adapters that you can get that just have a midi connector to usb adapter. There are external sound card devices that will do this like the tascam 144. There are also simple devices made my midiman such as the 2x2 midisport that allows you to connect up to 2 midi devices to a computer. The cheapest quickest method if you are just starting out is the midi to usb cable though. Places like walmart, best buy, and radio shack will generally have these. However with making digital music the cheapest is not generally ideal but will get you by in the meantime.If you ever plan on recording audio like vocals or guitar then I would recommend just getting something like the Tascam 144 MK II as it will allow you to input midi, spdif, vocals with phantom power, guitar line in, through it with 24/94 bit conversion, audio drivers, and a bit of software for simple settings configuration. This would be more of an intermediate interface. If you want some pro solutions, then I would recommend going to the pro's at a musician store and talking to them.
May 21, 2012 | Steinberg Cubase SX3
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I want to transfer some midi files to my Casio LK-230 keyboard. When I plug in the usb cable it does recognize the casio unit but it does not show up on my computer...like there is not unit... How do...
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
Apr 03, 2011 | Casio LK 230 Lighted Personal Keyboard, 61...
I have an Alesis io2 audio-interface and a macbook pro. I'm using garageband software. I plug the interface into the macbook before I load garageband. (So standard protocol.) My problem is that when I...
sorry about your problem, i have the same issue. i think i solved i'm by using my midisport 2x2. Alesis fucked up on the midi with this unit. use an other midi sort, and that may fix the problem.
Jan 06, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Connecting Clearco HD9000 Projector
I'm not familiar with that particular projector, but I believe I can help you get a couple cables to hook them up.
According to some specs I found * the projector has a VGA connection. Next we need to figure out which MacBook Pro you have. Does it have a silver keyboard or a black keyboard? If the keyboard is silver, you need a "DVI to VGA" cable, at least a metre long. You might want a longer one. If your keyboard is black, your MacBook Pro probably has Mini Displayport. That's a bit more exotic, but I'm sure you'll be able to find a "Mini Displayport to VGA" cable.
You can also get adaptors and then use regular cables.
For audio, I believe they're called 3.5 mm stereo plugs. So you'll neet a 3.5 mm stereo plug to 3.5 mm stereo plug cable. Make sure it will be long enough.
Apple sells both kinds of cables. If you want to save money, you might shop around. I don't know UK stores, so I don't know if I can help much there. I buy my cables at www.monoprice.com, an American site.
* http://www.electrobuys.co.uk/special_detail.asp?prod_id=458&grpid=458
Hope this helps.
Good Luck!
Bot
Apr 09, 2010 | Apple Computers & Internet
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Recognizes the midi interface but not the keyboard
Sir,
I am using lenovo system IBM & this system format, but sound card not match this system.  You are requested to please solve the problem.
Dec 23, 2008 | M-Audio Audiophile USB Audio and MIDI...
Edirol UM-2EX External Sound System Logo
112 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
