Question about Panasonic PT-47WX49 47" Rear Projection Television
Chassis number is DP820, also after sending the question to you I turned the tv on and no picture. I looked at all three guns and none were on. I can hear the high voltage come up and see the filaments lit. Also the sound works but takes about thirty seconds to come on with a whinning noise coming from the speakers before it comes on (no picture). Going back to the no picture, when I lost the picture I smelled something burning but was unable to identify where is was coming from. Thanks
  • Mason kid Apr 07, 2008
    That did the trick!!!!!!!! However you said that after replacing the ICs 7001 and 7002 that I need to go through the service menu and make adjustments. Can you walk me thru that step by step.
    My convergence all three color are really bowed top bottom and really all over the screen, middle is better than the rest.
    Thanks!!!!!!!!
  • Panasonic Master
  • 5,138 Answers
That would be capacitor feeding off your hori output Transistor NTE2973 cap 1200pf 2k volts .
Posted on Apr 06, 2008
  • ladywinn
    ladywinn Apr 07, 2008
    Do you have factory hand unit that came with set ? IT is a must inoder to get inside service menu.look up this address http;//www.freelists.org/archives/teachassist/09-2005/msg01112.html ,here is were you will find how to enter service menu read very carefully .If you need anymore help let me know.
SOURCE:
What is the problem to my Sony TV model KVXS29M65 Chassis BG-3S\51 that had a red tinted screen.Human skin tone looks reddish orange.Pse help.tq
I was not able to find any service information for that particular model. But it could be several things, first it may be that the picture tube has a short on the RED Cathode. If this is the case, toss it, if you could find a new picture tube it would likely cost more for the part than a new TV. Second it may be that the CRT Driver IC for the RED Cathode has shorted. This will be found on the CRT circuit board. There should be three of them, One for each gun, RED, GREEN and BLUE. Unfortunately like I said, I couldn't find the service manual for this model, so I can't give you a location number. They should be fairly inexpensive, so you could replace all three. You can find the part number printed on the face of the IC. Third it may be in the Chroma Circuit, which is also an IC, but again I cannot give you a location number. If your adept at repairing TV's and want to tackle this your self, invest in a service manual, or call one of your local repair shops. Maybe they can / will help with part numbers / location numbers etc.
Jun 13, 2010 | Sony Televison & Video
Comes on and blinks three times, hold in on 3rd time
It sounds like youre describing a RCA or GE tv with the ITC222 chassis. If so replace the flyback and CP150. If I had your model number and chassis number I could assist with the flybacks part number for you
Jun 09, 2009 | Televison & Video
I have a projection tv that as gone a little fuzzy, a little to the side, and there a blue blur behind all the objects on the screen. how do I fix it? The model NO. is PT-47WX51CE and the chassis NO. is...
You will need to replace the convergence ICs they are both STK392-120 and you can get replacements at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Panasonic Televison & Video
R52WH76
Thats usually a sign of a bad flyback. I am not famillar with that model number, if you can post the Chassis number off the rear tag I should be able to help you out.
Jun 12, 2008 | Televison & Video
No sound no picture
That is usually caused by the horizontal output cisrcuit or the flyback. Can you post the chassis number as RCA has to be diagnosed by chassis number.
Mar 29, 2008 | RCA P52937 52" Rear Projection Television
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
Manual
Have to find that by the chassis number what is your Chassis number and I will post a link where you can get the full service manual for your set. The chassis number will be located on the rear panel of the set.
Feb 26, 2008 | Televison & Video
The TV Turns its self off
Can you check the chassis number on your set I think its the DPTV916 . It should be located on the tag with the model number. Need to know tha chassis number then I can offer some suggestions on what to check.
Feb 23, 2008 | Philips 43P8341 43" Rear Projection...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
