Question about JVC TH-M303 System
Need a cable
I just got a TH-M303 from a friend but he lost the cable to connect the sub to rec. Where can I get one. Thanks
  • 1 more comment
  • Ivan69 Apr 11, 2008
    radio shack does not carry that. Anyone else?????
  • cableme May 27, 2008
    Pin out Diagram is required for this cable! if somone has this unit or the TH-M508 and could test their cable then post results
  • rolly15 May 11, 2010
    I just bought a home theater speakers from a friend,made by JVC, model SP-THM45. But the recent owner lost all the cables and wires. Where could I find or buy the cables/wires for the speakers and will it work if use a diffrent brand of dvd player? I'm from new zealand. Hope someone could help me where to find it.Thanks
  • 682 Answers
Radio shack near you.
Posted on Apr 06, 2008
  • Anonymous Apr 12, 2008
    any electronic or audiovision store near you.
SOURCE:
Th-m303 sub dont sound when playing dvd
Please try and connect the DVD using the coaxial or the optic cable so that the input is seperated to perrform on the amplifier with a true DTS.
Oct 26, 2011 | JVC TH-M303 System
Sub would only sound when am listening to radio would not sound when playing dud aux but surround speakers play
Possible that the connection to the AUX does not activate if you are using RCA inputs. Connect the DVD using the optical cable or the coaxial link and it must play better with surround and subwoofer in DTS.
Sounds cuts out if volume is over 30
hey
I have been has same problem for long time, actually problem was on and off... the reason was short circuit of speakers or speaker connections.
I find a little peace of cable stack inside of the connection handle. you know all the cable stick on back...
well what you can do is, unscrew all the screw back and the bottom of the box. slice the electronic box, just check connection piece is clean cable free....
use always clean cable and don't put it too much.
it is very easy to fix
http://www.myfixtips.com/blog/av-receiverhome-theatre/no-sound-from-jvc-th-m303-home-theatre-system-456.htm
Oct 11, 2009 | JVC TH-M303 System
Jvc th-m303 sub woofer not working all other speakers are fine
check your internal wires inside subwoofer.b4 that try to connect to other instrument to make sure it not working.
May 12, 2009 | JVC TH-M303 System
I can't seem to be able to get sound through the speakers when i am on cable tv. does anyone know how to fix this problem?
Run a set of phono cables from the tv audio out put to the aux in put on your system and set to prologic.
Hope this helps
CABLE GUY.
May 09, 2009 | JVC TH-M303 System
How to connect dvd to sub woofers
You need the sytem cable that goes with the system--see if your mate still has it 'cos they cost about £23 to replace
Jan 04, 2009 | JVC TH-M303 System
Subwoofer
often your sub need to be change because of its malefunction.
Mar 09, 2008 | JVC TH-M303 System
No sound
please check cables between dvd and subwoofer.test with good new or working cables.
Jan 20, 2008 | JVC TH-M303 System
JVC TH-M303 System Logo
85 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
