Visonic David 80 speakers - replacment drivers
I am trying to track down replacement HF drivers to suit these units - but its about 15 years since i changed them last and loaned to my brother-in-law (never again) and when i got them back - hey presto - no top end!
Where should i look in Australia for these (or suitable alternative) parts?
Thanks so much - Craig.
    Problem Solver:
  • 18 Answers
The Speaker Exchange www.speakerex.com has replacement tweeters (or woofs too) and can ship overseas
Posted on Jun 25, 2009
    Problem Solver:
  • 6 Answers
I'm not sure down under, but check with ORANGE COUNTY SPEAKER in California. They are online and most likely will have replacements. They may ship overseas. Watch the VAT!
Mister Phil
Posted on Apr 09, 2008
SOURCE:
No HF & weak LF response in a Yahama DXR-15 powered speaker
This unit has a class D switching amplifier which is complex enough to be unfixable by you unless you know what you're doing. It would seem from your diagnostic report (dodgy HF LF response) that you're not in any way a qualified bench tech and all you can do with this item is break it further. My advice - since it's still covered under warranty being that it's rather new, return it for a no cost repair at the store where you bought it.
Nov 19, 2013 | Yamaha DXR15 15" Active Speaker
Hi Dear Support Team I just bought KEF Q300 speaker from online market in US and ship that speakers to Malaysia. Once I got it found that the HF of one speaker is not functioning. Please help me with...
Since even the KEF website has no manual for this model http://www.kef.com/us/support/download we're on our own.
In the picture of the rear panel look closely at the speaker posts and those silly link knobs for each one. Unless you're biwiring (BUY wiring) those minus contacts should be electrically connected to each other and the positives to each other. Most other speakers with this dubious capability have simply jumper bars in place to ensure continuity.
http://www.enjoyaudio.com/zbxe/?document_srl=2781068
I'm thinking you either have a mis-set Link Knob or one of them has simply failed. With volume turned down to something medium try manipulating them to see if the HF driver wakes up.
You can prove that the HF driver works or not by attaching the speaker wire directly to it (top pair).
No matter what the result I would advise you to contact them and demand a manual be made public.
http://www.kef.com/us/Contact
Jul 14, 2011 | KEF Q300 Speaker
How do you remove the HF driver in the JBL EON 15 G2's??? Cheers Glen
If the cabinet is all taken apart, unplug the white and blue wires and unscrew the driver counter-clockwise to take it out
Feb 28, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
The high frequency driver doesn't work, the protective resin appears to be melted can you diagnose the problem?
Overloud... overheat... get a coil replacement for your HF driver and replace it. Just 2 wires to solder.
Dec 01, 2009 | JBL Speakers: CONTROL5 clearance Computer...
JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Tweeter not working on 15" EON G2
I have the same problem and the same conditions.
The tweeter is good, 3.8 ohms.
Some points of solding (donuts), have bad aspect.
I resolder the power transistors to the PCB and I solve the problem.
Jun 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Blown Compression Drivers
This unit features 2 -10" passive speakers and HF horn/driver. If you are blowing the HF driver, the problem is with overdriving the high range of EQ. At sustained high volumes, the voice coil of HF driver will overheat and open. If you still have effective warranty, ask Yamaha to replace drivers. Fixed,-- back off higher frequencies of EQ, turn down volume.
Apr 16, 2008 | Audio Players & Recorders
Microsoft Digital Sound System 80 - Parts
Same here!
Silicon seal fixed for a while ... ripped again 3 months later.
Apr 05, 2008 | Audio Players & Recorders
668 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
