Question about Sony Ericsson K800i Cellular Phone
Bluetooth not working
My blue tooth is not working despite being turned on, don't know what to do. Can you help?
  • m4xin8 Apr 07, 2008
    my bluetooth was working fine untill to day now it stoped working carnt send or recive can it be fixed ! or why has it just stopped working eney help would gratefull thanks maxine
    Brigadier General:
  • 7,752 Answers
You need to reflash the firmware on the phone,
Posted on Jun 08, 2008
The location of your Bluetooth program varies depending on your operating system and brand of Bluetooth software.
The Bluetooth icon is usually in the Control Panel or the Start menu.
If you can't find it, click Start, click Run, type bthprops.cpl, and then click OK.
If this doesn't work, your Bluetooth software might come from someone other than Microsoft, for example, from your computer manufacturer.
See the documentation that came with your computer for more information
Click Start Then click on Control panel and check and see if there is anything that refers to blue tooth and activate it.
If that doest work go to my computer right click on my computer select properties then hardware then device manager then scroll down look for
human interface devices see if it is there or anything with blue tooth on it and there it should allow you to enable it
if you are sure that there is a blue tooth in your computer you may need to check in control panel or start menu programs
if you are not sure that you have it then you have to make a right click on my computer manage - devices
and then check if there is a blue tooth hard ware or not
if not and your OS is not telling you that it discovered a new hard ware then you don't have any
hope this helps
Sep 06, 2012 | Soyo P4VTE (SY-P4VTE) Motherboard
How do you turn bluetooth on hp dv6 laptop
You have to go into start, then all programs, then look for the blue tooth connection setting. If you don't see it there then click Start, then All Programs, Accessories, Blue Tooth Wizard. You can turn it ON there. I hope this helps and thanks for using Fixya!
Sep 22, 2011 | HP Pavilion dv6000z Notebook
How do I set up my explorer 230 to work with an I-Phone 4
turn blue tooth on on your iphone under settings click general click on blue tooth make sure its on then it will auto serch the super tooth make sure its turned on
too easy let me know how you went
Mar 01, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I don"t know how to put my blue tooth in discoverable mode
Try this:
1. With your headset turned on, simultaneously
press the listen volume adjust button marked
+ (volume up) and the call control button.
Release the buttons when the indicator light
begins to flash red then blue.
2. While the headset is flashing red and blue,
use the phone menu to search for Bluetooth
devices and select "510 Plantronics".
3. When prompted for password, enter 0000.
The headset will flash blue when paired
successfully.
Don't forget to rate if this was helpful :-)
Sep 19, 2010 | Plantronics Explorer 230 Bluetooth Headset
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
I am using i-mate JAMA 1) I wana know about Bluetooth; how to send and receive files through Bluetooth. 2) how to Turn on WiFi Service and GPS Service Thanks Regards
turn on your blue tooth by clicking the bluthooth sign on the bottom right of your device. and check both the options that appear then( turn on blue tooth and make my device discoverable to all) then your blue tooth is on. ok then press and hold the menus on the file u want to send. when u do it, just beam your file. when u do it. then the device will look for all blue tooths on at that time. select the name of bluetooth u want to send the file. ur problem is solved. by a cute pakistani. love u.
Jan 25, 2009 | i-mate PDA2k Pocket PC
To install right bluetooth device in my sony lap top
how to enable bluetooth in sony laptop model: VGN-FZ430E
Oct 04, 2008 | Computers & Internet
Dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth broken
dear,maybe its because of bluetooth recieving list saturation. so delete all previously detected bluetooth devices
regards
dont forget to rate it
Nov 07, 2007 | Sony Ericsson Z530i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
22 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
