Question about Epson AcuLaser C900 Printer
Epson c900 toner rest
Hi
Would be grateful if you could let me know how to do this,
Regards,
Steve.
  • therocs May 23, 2008
    What I would like to do is;
    to refill the existing toner cartridge and consequentially trick the printer into accepting it back as a new cartridge.
    Thanks,
    Steve.
  • labatt May 11, 2010
    hi steve and Guest
    your questions are rather too open
    1. Do you want to remove a toner catridge from the printer?
    or
    2. do you want to refill the existing toner cartridge and consequentially trick the printer into accepting it back as a new cartridge.
    or
    3. which toner is better for refill purposes of the acculaser family.
    all the above have lengthy details and explanation. Kindly clarify
    labatt
COULD YOU ADVISE ME HOW TO CHANGE THE INK
Posted on Apr 30, 2008
How to install printer catridge
Locate Empty Toner Cartridge
  • Turn off your Epson C900 printer and unplug it from your computer and from the electrical socket. Open the left-side panel of your C900 printer and locate the toner cartridge you want to replace. Epson has labeled each of the four cartridges.
Remove Old Toner Cartridge
  • Stick a finger in each of the holes in the empty toner cartridge. Pinch your fingers together and then slide the cartridge out from the printer's interior.
Insert New Toner Cartridge
  • Remove the new toner cartridge from its packaging and shake it vigorously to remix any settled toner. Take the cover off of the new cartridge by lifting it up and out to the right. Slide the new toner cartridge into the empty slot in your C900 printer. Close the left-side panel of your C900.
Oct 07, 2012 | Epson AcuLaser C900 laser toner
How to replace catridge
Oct 07, 2012 | Epson AcuLaser C900 Printer
I want to change the colour toner cartridge but it isn't empty - I can't move it round to release it
Assuming you are using Windows:
Method 1: Using Software.
Go to Start Menu
Open 'Control Panel'
Open 'Printers & Faxes'
Right-click on 'Epson AL C900'
Select 'Properties'
Select 'Optional Settings' tab
Select 'Printer Settings'
The option at the bottom lets you select which toner you wish to change.
Method 2: Mechanical Solution.
Switch the printer off
Open the front door
Just inside the door, on the left, just above half-way down (to the left of the toner-changing aperture), look for the following:
A horizontal rectangular hole with four raised plastic posts (2 above / 2 below). Behind the hole is the end of a hollow plastic rod.
Use a broad-bladed screwdriver to push this spring-loaded rod about a centimetre into the machine. That releaces the ratchet and the cartridge carousel can be rotated anti-clockwise by hand.
Oct 10, 2009 | Epson AcuLaser C900 Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
C900 Colur print problems
Print a self made test page in word, a bar of bright yellow, bright cyan, bright magenta (almost pink) and black.
You might find one is completly missing, if so its a faulty toner or maybe the pull strip did not rip out correclty.
Jun 23, 2008 | Epson AcuLaser C900 Printer
Toner Capacity
This does not need to be done. there is a chip/fuse built into the toner that basically tells the printer how many paes that toner has printed in its life time. no adjustment is needed it is all automatic
May 31, 2008 | Epson AcuLaser C900 Printer
The magenta & blue rollers on our Epson Aculaser C900 are printing in stripes.
quick check
1. are you running out of toner magenta and blue??
2. remove magenta and blue, shake them gently HORIZONTALY to evenly distribute the toner inside (the toner container internally has a spade that feeds the toner dust to a spongy roller then to the roller u see on the outside :) )). DON'T HANDLE THE TONER CARTRIDGE VERTICALLY ---ESPECIALLY WHEN U ARE LOW ON INK---
3. on photo conductor read my article
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
May 02, 2008 | Epson AcuLaser C900 Printer
Colours printing really faint
dear sir you should check the colour mixing detect sensor
Sep 26, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
