Question about Iomega REV Tape Drive
Cartridges will not stay in & cannot see the device in 2003 enterprise
Hi
I was given a Rev 35/90 USB external drive from work (ex unit from backup process).
When powered up every time i insert a cartridge (i was given 3) after around 5 seconds they all just eject - they wont stay in.
I've got the device connected to a dell 2940 poweredge server running 2003 server enterprise. I've installed the latest driver software from iomega and the device now shows as a USB disk under disk drives in device manager not as a CDRom as it did before the drivers.
Am i missing something basic? Do you think the device is faulty?
Any Sugestions.
Cheers
Mark
Turns out the PSU unit was weak. It couldn't provide the power needed to spin up the disks when inserted.
Problem Solved.
Posted on Apr 07, 2008
Bought a seagate backup plus hard drive to backup files, installed on computer but cannot backup files, problem says could not be performed because of anI/O device error.
Connect the external drive to a different computer, and try to copy a few files to it. If you still get "I/O Error", then the unit has malfunctioned.
Mar 09, 2015 | Seagate Backup Plus 1 TB USB 3.0 Portable...
USB Port pushed into the Maxtor Backup - how do I open up to fix it?
Hi, this video should be helpful to you:
Once you have extracted the hard disk from the case you can either try resoldering/replacing the damaged USB connector/port or replace the shell/caddie with another one.
Mar 20, 2014 | Maxtor OneTouch 4 500GB External USB 2.0...
How to format sandisk ultra backup usb device?
Hi, please follow the following steps.
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
hope this will be helpfull to you. Please rates me .
Goodluck.........
Feb 03, 2011 | SanDisk 8GB Ultra Backup USB 2.0 Flash...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
Mine will work on my desktop but not my notebook
This is usually a corrupt USB driver for the device. On the machine that has trouble recognizing the drive:
right click my computer
click on properties
click on device manager
find the USB devices, click the plus sign to expand the tree.
Plug in your drive, see which new device appears, if it has the exclamation point, then right click on the device and click uninstall. Reboot the system.
Aug 09, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Segate 1TB not working with Windows 2003 Server
Is this an internal disk, or an external backup device? Two possible routes:-
Internal disk:-
Ok first thing: Does the BIOS see the drive? If not, try flashing the Server's BIOS to the latest version. Check that the system will support disks >500Gb. Try turning on LBA in the BIOS. It shouldnt affect it, but has been known to.
If its not showing here, its either faulty, dodgy cables, or not supported.
If its visible in the bios, great. Make sure you have at least one and preferably all the service packs installed. Gold (RC) only supports 500Gb drives.
Make sure you have Chipset drivers installed for the mobo. If its visible in the disk management console, then create a small disk, NTFS.
External backup device:-
Either you will need to install the software in 'compatibility mode' for xp, OR
dont use their software at all. Just plug the disk in, and it should appear as a removable device. Then use the windows backup tool to create a backup file on the external disk, and run a backup using that.
Jul 12, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
REV 120 freezes windows explorer in windows 2003
I have had this problem and found it to be the tapes are the cause.
Last week this same problem happened and 8 out of 10 tapes are causing this freezing suddenly. the other 2 work fine and brand new tapes work fine too.
Jun 23, 2009 | Iomega (32961) External REV Drive
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
External hard disk installation
plz check your usb port if other device read ...........then your external hard disk so error. or if ex hard ok...you install windows vista .
Jan 19, 2008 | Computers & Internet
Iomega REV Tape Drive Logo
412 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
