Question about Samsung SlimFit TX-S2783 TV
How to connect dvd
How to connect my dvd
If you use the standard red white and yellow connections from the back of your dvd player to the back of the tv on the in portion it will work. just make sure the tv source is selected as AV1
Posted on Aug 22, 2008
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
No to hook sound bar to element TV and my DVD player at the same time
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
Connecting set top box to dvd recorder
connect RF output of STB to RF i/p of DVD recorder.
connect stereo audio jack with same jack of DVD recorder.
now
connect DVD recorder with TV,
connect RF o/p of Recorder with TV
audio o/p with TV
Oct 20, 2012 | Televison & Video
How to connect austar and a blue ray DVD player to tv
your connection is wrong. Get a RCA wire. Yellow is video and white & red are audio.
Connect the wires to Output from the DVD. Video out and audio out. All that will be connected to the DVD will be output. The DVD is feeding out to the TV, so it is giving.
Now the all connections to the TV will be input. Because the TV is receiving from the DVD. Connect from the DVD to TV respectively.
Turn on the TV and DVD, then press Souce/AV on the TV. Now you should see a display and hear sound from the DVD through the TV.
I hope the above is clear. If not, please let me know.
Good luck.
Jan 04, 2012 | Televison & Video
How to connect a dvd player to a tv set
Connect the incoming antenna to the DVD player (look for connections on the back of the DVD player for Antenna In). Then connect the Dvd player to the Tv. Use the "out" connections on the back of the DVD player and the "in" connections on the back of the tv. You can use RCA jacks to connect the DVD to the tv, or any other type of connection available. Once the DVD player is connected to the tv, you need to set the incoming source on the television. Click on the source button until you find the one that has a clear picture. Dvd connections are usually listed as "aux 1 or 2" on the tv source choices. You will know when you choose the right one because the picture will come in on the tv.
Hope this helps?
Sep 12, 2011 | Televison & Video
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
How to connect to tv using converter boxs
DVD does not need to go through converter box.
The converter is only to receive the digital TV through the antenna. DVD might have to switch to another connection on the TV, and if it doesn't have enough connections, you have a problem.
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Samsung SlimFit TX-S2783 TV Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
