Question about Dell Inspiron™ E1505 PC Notebook
Adding mor memory
Dell Inspiron E1505
Can I add more harddrive space. Now 50gb would like 100gb or more
can you do it? if so, how much.
What happens to my present files and data?
    Scholar:
  • 58 Answers
A laptop can only have a single internal harddrive but you can replace your current drive with a larger one. The cost will depend on the size of the drive... goto the dell site and get your drive specs then goto a hardrive manufacturer site like Maxtor and see what size drives are avialble with the same specs ... you will have to backup and transfere all your files and also reinstall all of your applications and OS...
Posted on Apr 06, 2008
Memory card reader driver
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-e1505
Oct 18, 2012 | Dell Inspiron E1505 Notebook
Put in another HD made it a slave but i dont see it as a slave in system files
The master/slave drive model applies to IDE drives (older) these use a 40 or 80 pin ribbon cable. The newer SATA drives (L shaped connectors) don't rely on master/slave config. If you are using IDE you will need to specifically configure the jumper on the main drive as master and the other as slave, alternately you can set them both to cable select. The slave drive will show up under disk management as Disk 1. If you add a second disk this will give you more storage space, in this case 50GB (think of this a long term storage or data that is saved after the computer is shut down) Ram on the other hand is where the computer stores data and applications for faster access, not all of a program has to be loaded in to ram, parts of it can be swapped out from your hard drive as needed. Having more ram means the computer doesn't need to waste time swapping out parts of a program, it can load it all into ram at once.
Feb 03, 2012 | Computers & Internet
Problems with dell laptop slow operating too many downloads????
You can download everything until you have free space on HD drive. But you need at least 20 (minimum) percent of free space on disc for operating system.
That model usually have installed 80Gb hard drive and it is very good laptop and if you want to upgrade that laptop just replace disc with bigger one and add more ram memory (2Gb).
Feb 23, 2010 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 charging port is bad
happened to me.... tech guy from dell came over, and temp. fixed it ... laptop is then no use with battery, i still always have to use the plug
Oct 21, 2009 | Dell Inspiron E1505 Notebook
Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
May 04, 2009 | Dell Inspiron E1505 Notebook
I need more ram to run photoshop
There isn't anything you can do. The amount of ram that a computer can hold or process is dictated by the motherboard that the manufacturer installed
Apr 05, 2009 | Dell Inspiron 6400 Notebook
I add memory to my gateway laptop.
maybe the memory is not compatible... there is a dsgnated memory speed... take it to the experts.. dont try to kill ur laptop..
Jan 25, 2009 | Dell Inspiron E1505 Notebook
When I try turning my dell inspiron e1505 laptop on, it doesn't boot up all the way and says that there are no bootable devices found on the computer. i ran the setup test or whatever, and it failed the...
Try to listen the noise coming from H-disk and note that its normal or abnormal.. like clicking or something....
Remove your H-disk a try new one... its surely a H-disk issue...
regards,
Dec 03, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Memory
Try a memory manufacturer website & plug in your computer:
PNY:
Capacity PNY Part Number Retail Part Number OEM Part Number 256MB Module 6432SDTYE N256X42OPT N/A 512MB Module 6464TDTYE MN0512SD2-533 N/A 512MB Module 6464TFTYE MN0512SD2-667 N/A 1GB Module 64A0TDTYE MN1024SD2-533 N/A 1GB Module 64A0TFTYE MN1024SD2-667 N/A
HD 'memory' is considered secondary or storage.
In <Control Panel>::<Add / Remove Programs>, it should give you some indication of the size of the programs, as will hovering the mouse over the folder in which the program is situated [not as reliable as it once was as many dlls are stored in windows folders].
Jul 18, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron™ E1505 PC Notebook Logo
74 people viewed this question
Alun Cox
