Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5013/sys-5013g-m.cfm Is your Mouse a USB mouse or is it a HYBRID Mouse? Look at the bottom
of mouse and see what is written. It should give you the: (1-) Name (2-)
Model Number & it will either say: "USB Mouse" or "USB 2.0 and PS2
Compatible". If it is USB 2.0 and PS2 Compatible, then it is a HYBRID
MOUSE - You should have a - USB to PS2 - Adapter that came with the
mouse.
Use that adapter and plug into the PS2 Mouse port - (only if it is a
HYBRID). It will automatically configure itself as a PS2 mouse. Now you
will have both your Input devices set as PS2.
(2) - If it is a USB mouse, can you obtain a PS2 mouse to temporarily use? If you can; try using the PS2 Mouse Port?
Now you may have to set BIOS on - with regard to:
(1) - Legacy USB Support -(Either Support or Disable)
(2) - USB settings to what Motherboard supports
Try also to upgrade the drivers/bios, if nessesary.
SET LEGACY USB SUPPORT TO "DISABLED" FOR BOTH MOUSE & KEYBOARD IN BIOS.
Good luck
