Question about Dishwashers
My dishwasher has stopped mid cycle showing 1 minute left , when stopped and started again it now shows 28 minutes contantly, plus it continues to run (ie pump running) after the door is open. Any ideas ? many thanks Doug
  • dcp667 Apr 08, 2008
    I've taken the door front off and had a look at the connections inside all seem ok ,user the user manual I,ve zeroed the timer , ie reset it but whenever its turned on the pump runs continuously . like its stuck on the same part of the program as you suggested ,where do I go next ? Its a freestanding slimline model where are the rest of the electrics ?
  • Anonymous Mar 26, 2014
    LIKE J SAID ONE YEAR BEFORE STARTED TO SHOW ERROR F3 SOMMETIMES NOW WHEN WE RUN ANY WASHING PROGRAM, THE DISHWASHER IS DOING LIKE THE WASHING IS ENDING[GEETING WATER INSIDE IN DISHWASHER AND AFTER ALL THE WATER IS GONE, ALL THE DISHES AND CUTLERY ARE LIKE BEFORE WASHING-DIRTY AND DRY
  • 871 Answers
Hey dcp667
Dishwashers are incredibly durable machines. They can take years of daily use and in many cases, it's only a change in decor that brings about a replacement. Of course that doesn't mean things never go wrong with them. From time to time a motor may go bad here or a leaky hose shows up there. But all in all, the dishwasher is an ingenious appliance that uses both electricity and water to give us years of dependable service.
to check the electrical parts of the washer, you will have
to open the dishwasher door, unscrew the screws holding it in place underneath the countertop and shimmy the unit out. The junction box is located at the rear, on the bottom. Open the junction box and check the wires for corrosion, breaks, or loose connections. Check the interior of the box for any burn or "arc" marks. If everything is clear, turn the power back on and check for voltage by probing the black and white wires.
the way you described the problem, it loks like that the dishwasher has a faulty sensor and program.
post back for any more questions and devepoments.
Posted on Apr 06, 2008
  • earl norman llanera
    earl norman llanera Apr 08, 2008
    hey doug,
    any news on your problem?
    Genius:
  • 3,422 Answers
HI,
Does the water drain out.If the water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again.
Please don't forget to rate the solution.
  • Priya darshan Apr 06, 2008
    If your problem is solved then please don't forget to rate the solution no.2
SOURCE:
LDS4821ST HE error...new heating element already installed
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Sep 28, 2016 | Dishwashers
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
Fisher and paykel DD605SS
hold all three bottons: power, pause and start and power cycle the unit, it will reset the dish washer.
Nov 22, 2008 | Fisher and Paykel DD605SS Stainless Steel...
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
