Question about Motorola Mobility RAZR V3xx Cellular Phone
File corrupt motorola v 3. a song was used as ringtone & alarm clock. i tried to delete song but with failure. i changed song name and i deleted it. when i tried to receive another song via bluetooth it says it`s corrupt. since i deleted the song used as alarm, my alarm clock dont want to adjust wake up time or exit like as if the buttons is not clickable. i did master reset but not master clear. i removed battery but still it dont work. i cant receive mp3,amr or any other formats. all songs are under 128 kbs. i dont know if it is a software error on the phone after i deleted the song/s. please help.
If is not charging
Posted on Apr 06, 2008
SOURCE:
How to change my message tone to my samsung galaxy pocket?
following ways to change sms tones and alarm tones on phone android
1. create a folder named "notifications" (without quotes)
2. input file that will be used as ringtone notifications to the folder "notifications"
3. now you can change sms notification with your favorite song or other ringtone
Sep 06, 2012 | Cell Phones
How to delete phone ringtones in corby 2?? they are write protected!!
You cannot delete the default ringtone, still if you want to delete the saved downloaded ringtones just go to the saved location and in options you will find delete.
hope this helps, please rate and leave a comment if the solution was helpful ,thanks!
Nov 02, 2011 | Samsung GT S3850 Corby II
How do i set my music as a ringtone on iphone 4
It's a very tricky method. Follow these step precisely, and you should have your own custom ringtone like I have.
Please rate this solution if it helps you.
1 Open iTunes.
2 Find the song that you want to make into a ringtone.
3 Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
4 Write down the start and stop times of the clip.
5 Right-click the song and select "Get Info."
6 Click the "Options" tab.
7 Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., x:xx) format.
8 Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
9 Click "OK."
10 Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
11 Right-click the ringtone and select "Delete."
12 Click on the "Keep Files" button.
13 Find the file. It's usually in your User folder under "Music > iTunes > iTunes Music" and under the band's name. It will have an extension of m4a.
14 Replace the m4a extension of your ringtone with m4r. You can either double-click slowly to rename your file, or right-click and select "Get Info" on a Mac or "Rename" on a Windows PC.
15 Click "Use .m4r" or the PC equivalent when the system warns you that the change may affect the use of your file.
16 Double-click the ringtone file. ITunes will automatically add it to your ringtones folder in your iTunes Music Library.
17 Connect your iPhone and sync your ringtones.
Oct 27, 2010 | Apple iPhone (16 GB) Smartphone
My memory card wont let me delete songs what can i do? the song i want to delete worked for two days ,then when i came to delete it , it said that the file is "corrupted" so everytime i try to delete , it...
SAVE YOUR CURRENT SONGS TO YOUR COMPUTER.THEN FORMAT YOUR MEMORY CARD.THEN COPY THE SONGS WHICH YOU WANT BACK TO THE PLAYER.DONT PUT THE CORRUPTED FILE BACK THIS TIME.HOPE THIS HELPS
Mar 06, 2010 | Coby MPC-848 MP3 Player
Deleting songs and corrupted files
try 2 reset ur phone go in secorties and reset ur phone ur secorty code is 00000. reply me
Jun 03, 2008 | Motorola Mobility RAZR V3
Razor v3 says files are corrupt
you need to re format the phone so that all the original files will be back... try the master clear on the settings
Feb 29, 2008 | Motorola Mobility RAZR V3
Krzr's bluetooth and ringtones are messing up badly
check the file name of the song and look if there is a lock icon beside it. if it does you wont be able to change/delete or send that file either by bluetooth nor mms.
Feb 10, 2008 | Motorola Mobility RAZR V3
WTF! "Bad Track" to Nothing!?
What I would recommend you to do is to update the firmware on the device even if you have done so already by going to
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
If after you have done the firmware update you are still having the same problem, please contact me..
P.S. Please rate accoringly
Thank You
Computerrep
Feb 07, 2008 | SanDisk Sansa E280 MP3 Player
When a ringtone is bluetoothed to me, it shows file is corrupt
you need to do a master clear on your phone ... you would loose ur pictures and any downloaded stuff, but your wouldn't get that file corrupt error again. Somehow your software probably got a glitch.Try the master clear or the master reset in settings and hopefully as i said this would clear the problem. You can then go ahead and try to bluetooth any files your want to. Sam !
Sep 02, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cannot delete ringtones
HI Below is the step by step method of how to delete your ringtones in your Motorola V3: Here is an easier way to delete the ringtones without much hassle. 1) Upload 1 mp3 rintone to your phone via MPT 2) Set ALL ringtones msg, alert etc, absolutely everything for all styles (obviously excl. silent & vibe) to the uploaded MP3 3) switch your phone off, then on again. This will update the .db files. 4) Using P2K, delete all the rintones, except for the MP3 that you uploaded, do not delete the .db files. Also, do not delete the .bas files as these are the base files for Motomixer. Set all reminders to OFF. do not EVER delete a ringtone that is currently in use by the phone. If you delete it while it is active, You will NOT be able to get into that particular tone setting. 5) Switch your phone off, then on again.
May 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
